Results 1 to 10 of 10
Thread: Beading Chisel
    Beading Chisel
    Try as I might I can't cut a bead worth while. Do any of you use the beading tools sold by PSI? Or from any other place? Are they worth the money?
    Dennis
    30,014
    I can't vouch for the PSI beading tools, but I know a number of very well-respected turners are very happy with the beading tools from D-Way Tools:
    http://www.d-waytools.com/tools-beadiing.html
    I have a couple of the Henry Taylor beading tools from Craft Supplies USA, but I've not used them enough to know if they are any good or not.
    S E Washington State
    3,777
    I have a couple od D-Waytools and couldn't be happier, well I could be if I bought all of them.
    "We the People ......"
    Goodland, Kansas
    4,834
    +1 for D-Way beaders. Can't be beat and I have tried the PSI along with several others. If you get a couple don't forget to get the tear drop tool. It is a great tool. He has video's on their use on his website.
    Bernie W.
    Aug 2008
    NorCal, USA
    495
    How do you sharpen them?
    Goodland, Kansas
    4,834
    I either hone them or sharpen them occasionally on the D-Way DBN diamond wheel. Here is a video showing how he does it. http://www.youtube.com/watch?v=lH9MQ...hannel&list=UL
    Bernie W.
    3,777
    One thing on beading tools, do not drop them! I dropped one of mine right after I purchased it. Broke a tip off one side. They are easy to sharpen though and it only took a few minutes to fix. I am going to get one of his hand hones though. With that you rarely need to go the the grinder I would think.
    11,831
    I have a mini beading tool bought from someone on a pen turning forum who makes them. I like and use it often. Larger beading tools haven't been something I felt I needed as I just make the beads I want with a skew tip. I cut two V gouges then sorta roll the skew over to make the bead.
    Jul 2007
    DSM, IA
    5,719
    I bought the cheap ones from PSI and they worked OK for awhile, but I'm not even sure where they are now...in other words, don't get the PSI ones. I've had lots of luck with their other tools, but the beading ones aren't worth it.
    My Website
    Aug 2008
    NorCal, USA
    495
    Bernie, thanks for the video. That’s too simple. I was WAY over thinking this.
  1. Scratch beading
    By Rob Keeble in forum Neander Woodworking Q&A
    Last Post: 08-27-2010, 01:54 AM
  2. Beading Busy again.
    Last Post: 06-15-2010, 04:05 AM
  3. Beading, how do you ...
    By Richard Line in forum General Woodworking Q&A
    Last Post: 10-31-2009, 04:11 AM
  4. hand cut beading?
    By larry merlau in forum Neander Woodworking Q&A
    Last Post: 03-27-2008, 12:53 PM
  5. Beading for Travis
    Last Post: 03-26-2007, 12:18 PM
