Results 1 to 3 of 3
Thread: I made this handle last night
    3,145
    The chisel is 8 1/2" long the handel is 3 3/4" long is the handle long enough this was just an experiment to see if I would get the tapered part of the handle right & I did. I haven't pressed the handle all the way home yet.
    Forest Grove, Oregon USA
    290
    Hi Bart--nice shape to that handle, good job.
    fwiw, being that it is a socket chisel, the socket should remain about an 1/8" from coming into contact with the shoulder on the handle. So if under heavy use, it drives down to the shoulder, a couple raps should loosen the handle enough to pull it off and turn the shoulder back a touch.
    btw, what wood did you use? I like the grain on it.
    Take care, Mike
    Wenzloff & Sons Sawmakers
    3,145
    Thanks for the answer Mike.
    The Handle wood is Cherry.
  1. Tap Handle
    By Darren Wright in forum Flatwork Project Showcase
    Last Post: 10-01-2014, 10:51 AM
  2. Tap Handle - WIP
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 04-29-2011, 02:54 PM
  3. handle is done
    By Mark Kosmowski in forum General Woodturning Q&A
    Last Post: 04-05-2009, 12:41 AM
  4. a couple of bowls I made last night
    By Zack Massey in forum Lathe Project Showcase
    Last Post: 04-27-2008, 03:23 PM
