Results 1 to 9 of 9
Thread: Air Cleaner remote problem
    17,475
    i have a general international super turbo model air cleaner with a remote switch, it will turn on but wont turn it off, also cant adjust the speeds on it now or the length of time it runs.. just get one led to light up and it will turn on but wont shut off.. took it apart to look inside and the switches on the board all look fine feel good but only one led lights up.. and antenna wire lays next to the board.. in order to turn it off i have to manually switch it off above on the unit now..
    Silly question, but does the remote have fresh batteries in it? I've seen that kind of behavior on other remotes if the batteries were weak.
    17,475
    vaughn thats why your still working and i am not,,, that did it???? now tell me why it would affect it like that..????
    12,264
    Well Larry you made a wise buy. My Grizz equivalent comes on simply from the light emitted by my lights being turn on. I dont bother with my remote anymore whats the point? i now use a piece of wood to press the switches.
    ... now tell me why it would affect it like that..????
    When there's only partial voltage, the framdamulator doesn't get enough picofarads of hyperbole to overwhelm the thrust bearings. It's really pretty simple.
    I honestly have no idea.
    Within a single integrated circuit, there are many circuits made up of transistors, and diodes. Though these individual components are all contained within the same "chip", they still can have individually different characteristics. Thus when the battery voltage gets low, some of the circuits can function and others can't or won't. I have troubleshot some really interesting and tough problems because of low power supply voltage(battery voltage in this case).
    Ken
    17,475
    thanks ken,, after the first unheard of word from vaughn i knew i was going now where fast in the answer he had for me your expeiernce makes sence.. as i do know a little about electronics, and the parts in there
    Los Angeles, CA
    2,668
    Ken's explanation makes sense but Vaughn's was much better.
    I have experienced this with my TV remote. When the battery was weak, I could change the volume but not the channels.
    Quote Originally Posted by Ken Fitzgerald View Post
    That's exactly what I said, but I didn't get all wordy about it.
  1. Paint Brush Cleaner
    By Paul Douglass in forum Turning Tool Questions and Show & Tell
    Last Post: 11-16-2012, 02:43 AM
  2. Tool cleaner
    Last Post: 06-21-2012, 05:37 AM
  3. Air Cleaner for Swap (07946)
    By Jim Mattheiss in forum Old Ads
    Last Post: 09-28-2010, 02:58 AM
  4. G0513X - Quieter and Cleaner
    Last Post: 05-17-2009, 04:33 AM
  5. Blade Cleaner - CMT Orange vs T.S.P.
    By Bryan Cowing in forum General Woodworking Q&A
    Last Post: 07-10-2007, 01:39 PM
