Results 1 to 10 of 18
Thread: Screen Porch Floor -- Suggestions?
    SE Minnesota
    2,524
    I'm looking for suggestions for a floor covering for our screen porch. Here's what we've got:
    • The existing floor is treated OSB glued and screwed to the joists.
    • The floor is level. Well, except where the edges of the sheets swelled after getting wet.
    • There's no more than 3/4" between the OSB and the underside of the sliding door threshold.
    • The siding on the house was trimmed right down to the OSB. Not fun to pull the siding off to put flooring under it but maybe we'll have to.
    • The floor is held back about 1/2 in. from the exterior walls to allow water to drain off. Of course being flat, the water doesn't do that anyway.
    • We plan to put car siding on the inside of the walls and leave it up off the floor a little.
    • the porch is 12 by 20 feet.
    The contractor told us it was a new kind that is weather proof. I was skeptical but trusted his judgment. Not so happy with it now. So I'm looking for some suggestions on what I can put down over it. Carpet doesn't seem like a real good plan. I figure it'll get wet when it rains in and just hold the moisture against the OSB. I looked into those vinyl floor planks. They looked promising but this is Minnesota where temps can be 20 or 30 below zero in the winter and up around 100 sometimes in the summer. The manufaturer of the vinyl planks says they're only for temperature controlled environments. If would be nice if the surface was smooth so it can be cleaned with a mop--I don't want to pressure wash it.
    Is there some sort of thick, somewhat flexible, durable coating that would go on reasonably smooth? Any other suggestions?
    Thanks in advance.
    Dave
    17,470
    what is the siding you have on there?
    SE Minnesota
    2,524
    On the outside? It's vinyl. And on the wall of the house, the same. There's nothing on the inside of the exterior walls yet but insulation and plastic sheeting. We'll be putting pine car siding on the walls. I think the photos are a little dark but the ceiling has pine beadboard.
    SE Minnesota
    2,524
    This is from last year the evening after the door was installed.
    NH
    4,005
    Sorry Dave nothing I come up with is going to be a likeable idea.
    Stupid hurts.
    North West Indiana
    6,097
    Linoleum?
    Jon
    Inside the Beltway
    2,666
    My solution to every problem is: tile!
    Bill
    17,470
    the vinyl siding can be removed and put back on fairly easily dave if that was needed to change the floor..what about some epoxy paint???
    SE Minnesota
    2,524
    Epoxy paint might end up being the way I have to go. I guess I'll have to look into it.
    Thanks.
    5,319
    How about one of those epoxy based coatings that use pea stone in the mix? They're somewhat flexible, and they look pretty good. I think there's a 'rubberized' variety, too. Depending on where you live, and who installs it, it might be a bit pricey, though.
  1. Putter Palace Porch
    By Carol Reed in forum Shop Tours
    Last Post: 08-14-2013, 06:08 PM
  2. Cypress Porch Balusters
    By Matt Hutchinson in forum Lathe Project Showcase
    Last Post: 04-03-2013, 02:50 AM
  3. Ash Porch Swing
    By Donald Stonecipher in forum Flatwork Project Showcase
    Last Post: 10-02-2009, 05:58 AM
  4. Porch ceilings
    By Jeff Horton in forum Carpentry and Construction
    Last Post: 08-30-2008, 03:02 PM
  5. Mahogany Screen Porch
    By Gail O'Rourke in forum Carpentry and Construction
    Last Post: 06-15-2007, 02:24 AM
