Results 1 to 6 of 6
Thread: Article: Steaming out a dent
    Central NY State
    3,374
    Bellingham
    2,450
    Ken, I just have to tell you that your tutorial came in very handy in my Splay Leg Table project. While working on another aspect of the build, I moved too fast and was not watching what I was doing and whacked the outside corner of one of the legs. This put a very noticeable dent right in the corner of the outside faces. Very upset was I, as planing or scraping it out would mess up the profile of the leg. I decided to try steaming it out as per your tutorial. A complication was that I had lightly shellacked the legs to prevent them from getting dirty. I was worried that it would prevent the steam from working. I should not have worried, as it worked perfectly! I just scraped the affected area to remove the damaged shellacked surface and level the slightly raised surface.
    Thanks!
    May 2011
    So. Florida
    268
    Steaming out a dent, or a hot iron/wet towel does work in many cases. That method does disperse a moisture penetration for an area larger than the specific dent. A dent represents crushed fibers, whereas a scrape or tearout can leave a void, which will respond somewhat by expanding, but not for a total repair.
    Just a suggestion, for hardwoods and plywoods, using an eyedropper and dripping a drop or two into the dent will raise the area. The applications may have to continue for several applications, but the wetted area will engorge and expand. Once dry, it seems less likely to shrink back as some wet/hot methods can have the propensity to do, when they cool (or dry out).
    Good tip. Charles Neil posted a video tip on this back in Dec. 2007. It is still on his site. He used DNA. Rob
    http://www.cn-woodworking.com/remove-a-dent-from-wood/
    Jun 2010
    3,220
    Great tutorial, Ken. By the way, when you buy the honey a new iron, get her a Rowenta.
    17,475
    i ran into a situation where someone was told to do this steam trick on a gun stock, in my opinion a well finished gun stock shouldnt allow the moisture into the wood and that is what makes the dent come back up.. so perhaps dave or frank can give me a solution to fix a dented gun stock that is already finished.. my thoughts would be to just fill the depression will more finish and sand flat till it is the same elevation as the rest of the finish... any ideas?
  1. Dent Steaming?
    Last Post: 07-11-2012, 03:53 PM
  2. Steaming out a dent - tutorial
    By ken werner in forum Neander Woodworking Q&A
    Last Post: 08-11-2011, 03:38 AM
  3. Steaming out a dent in veneer?
    By Paul Downes in forum General Woodworking Q&A
    Last Post: 12-03-2010, 04:40 PM
  4. Steaming out a dent
    By ken werner in forum Tips and Tutorials
    Last Post: 11-21-2010, 06:20 PM
  5. Steaming out a dent - tutorial by Ken Werner
    Last Post: 11-21-2010, 05:24 PM
