Results 1 to 3 of 3
Thread: This question has to do with mounting a lathe
    3,134
    The lathe I want has cast legs but the center height is 44 7/8" - 45" & I need approximately 41" & I want the underside of the lathe wide open for cleaning purposes & I want to be able to have a cabinet for tools, chucks & sharpening etc. on castors to roll underneath it. I am thinking of making ends 24" front to back & the height necessary to to achieve 41" out of steel reinforced concrete with a cross brace on the back this will leave the lathe open underneath & should add plenty of weight.
    Now for the question how do I figure the weight? The lathe is about 500 lbs. factory weight with factory legs I'd like to get somewhere between 700-800 lbs.
    30,008
    The concrete is going to weigh in the neighborhood of 135 to 150 pounds per cubic foot, so just come up with a design that has enough cubic feet in it to meet your weight goal.
    11,825
    Vaughn nailed it. Doesn't take a lot of concrete to get to the weight you want. BTW, 500 pounds is a lot already. Do yer thing and don't sweat numbers. Pic mandatory when done.
  1. Lathe question
    By Jeb Taylor in forum New Tools
    Last Post: 07-05-2010, 01:10 AM
  2. Mounting a TV over a fireplace question.
    By John Pollman in forum Off Topic Discussion
    Last Post: 03-21-2010, 12:49 AM
  3. Table saw motor v mounting question ?
    Last Post: 10-04-2008, 11:41 PM
  4. Table Saw Mounting Bracket Question
    Last Post: 09-23-2008, 04:45 AM
  5. Question About Lathe's
    By Scott Custer in forum General Woodturning Q&A
    Last Post: 11-20-2007, 12:27 PM
