Results 1 to 6 of 6
Thread: Can I ask about crosscut sleds?
    Jan 2011
    Mount Vernon, Ohio
    75
    I just built a small crosscut sled to aid me in box building. I used ½” phenolic faced plywood for the base with hard maple for the fence and Incra miter sliders. It’s only 12” deep since I never use lumber wider than 8” to 10” anyway.
    My question to all the experts and users of crosscut sleds is: How precise should I expect to get this set up?
    After 6 tries using the 5 cut method, I have 1/64” or .0145” difference in a 8” cut. Is that considered close enough?
    I just want my boxes to come out square along with some small molding I use on some styles I build.
    Thank you all in advance for your thoughts on this.
    Thomasville, GA
    5,998
    My feeling on tolerances is that the smaller the project, the more exacting you need to be. An error of 1/64" may not seem like much on a 5 foot by 5 foot box but it will have much more impact on a 5 inch by 5 inch item.
    Bill Arnold
    I shoot for about .001" over 12" or so. What design did you use to adjust the fence? I use t-bolts with tight fitting holes through the fence, oversized holes in the sled base and elongated holes to allow the heads to move forward and backward a bit. I loosen all four bolts, snug one of the ends . . .
ID:	67632 Click image for larger version.
ID:	67633 Click image for larger version.
    and just tap the fence the direction I want to go. Snug the other three bolts and test, loosen, tap, snug, test, etc. Takes a few tries but not many. Some have used a really clever threaded gizmo to allow very controlled adjustment. Maybe they will chime in. Smaller items are much less tolerant of deviation than larger pieces. A 30" square lower cabinet might accept 1/64" deviation on a miter but a 5" square box end would not IMHO.
    17,474
    another vote for tighter tolerances,, and if i were you i would make it to accept larger stock, think plywood pieces..
    Jan 2011
    Mount Vernon, Ohio
    75
    Thank you for your input.
    After re-reading the 5 cut method, I discovered that the final difference has to be divided by 5.
    Therefore, I really have a .0029" differential. I think that's close enough for my needs.
    But, Glenn, I really like your idea on fence mounting. How did you get the oval mortises in your base? I think I'll incorporate that concept in my miter sled.
    Quote Originally Posted by Roger Pozzi View Post
    I used a Forstner bit to drill two shallow mortises and then used a chisel to connect them.
  1. New 'smaller' Crosscut Sled
    By Ned Bulken in forum Jigs and Fixtures
    Last Post: 01-01-2013, 02:40 PM
  2. Crosscut sled
    Last Post: 11-22-2010, 07:36 PM
  3. Crosscut Sled Size
    By Steve Southwood in forum Jigs and Fixtures
    Last Post: 02-06-2010, 03:32 PM
  4. 90 and 45 degree crosscut jig RFC
    By Ellert van Koperen in forum Jigs and Fixtures
    Last Post: 12-15-2008, 06:12 PM
  5. Big Ol' Crosscut Sled
    By Vaughn McMillan in forum Jigs and Fixtures
    Last Post: 06-06-2007, 01:04 AM
