Results 1 to 8 of 8
Thread: Attaching a table top
    Dec 2008
    Santa Claus, In
    4,779
    How do you folks attach a table top? Do you use the figure 8 fasteners or something else? Got a friend that wants a small end table and looking for ideas to attach the top.
    I've used figure 8's, oversized holes through available under-structure, oversized holes through added cleats, shop made clips, etc. I have no preferred method necessarily. I use what works for a given construction. I lean towards K.I.S.S. on this sort of thing ;-)
    Thomasville, GA
    5,992
    I've used figure eights on a couple of projects; they work great. More recently, I've used pocket holes (since I finally got a jig last year!). I drill the pocket hole in the usual way, then elongate it a little to allow for expansion/contraction of the top.
    Bill Arnold
    5,170
    Figure 8's in oversized counterbores done with a brad point bit.
    Dec 2008
    falcon heights, minnesota
    5,609
    i've used nothing but figure 8's
    benedictione omnes bene
    www.burroviejowoodworking.com
    Dec 2008
    Santa Claus, In
    4,779
    8's it is then.
    17,471
    as glenn said i have used many choices as well, and you can use buttons to steve, cut a groove and make the buttons out of wood.
    new york city burbs
    10,188
    z clips for me. I use my biscuit cutter to make the groove in the aprons.
    Human Test Dummy
  1. Attaching The Flags
    Last Post: 07-15-2014, 06:21 PM
  2. attaching files
    By roger johnson in forum Site Questions and Test Posts
    Last Post: 11-15-2008, 03:47 PM
  3. Attaching Workbench Top
    By Homer Faucett in forum Neander Woodworking Q&A
    Last Post: 01-11-2008, 11:47 PM
  4. Attaching cedar pickets to rails?
    By Wes Billups in forum Carpentry and Construction
    Last Post: 10-10-2007, 10:29 AM
  5. Attaching PVC pipe to concrete
    By Dennis Thompson in forum Carpentry and Construction
    Last Post: 08-13-2007, 09:07 PM
