Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: clear filling knot holes
  1. #11
    Central PA
    489
    I scraped and sanded down the epoxy then sprayed lacquer on the table today. Except for some bubbles in the epoxy it worked really well. If there is another time I need to do this I think I will either try finding a thinner viscosity epoxy or mixing it up then putting it in a vacuum to pull the bubbles out before filling the knots.
  2. #12
    ABQ and LA
    23,249
    I've used a touch of denatured alcohol to lower the viscosity of Borg epoxy with good results. I'd only do it for cosmetic fixes though, not structural ones, since I don't know how thinning it affects the strength.
    Sent from my iPhone using Tapatalk
  3. #13
    Central PA
    489
    good to know
  4. #14
    Apr 2009
    Outside the beltway
    3,381
    If your use T 7 epoxy I don't see how you would get bubbles.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
  5. #15
    May 2011
    Cape Cod, Ma.
    1,227
    Im with the others in using West System. Ill also add a bit of Trans Tint or powdered dye to try and match any surrounding knots. If the knots or voids are small I will use Behlen's burn in sticks and try to match the finished stain so they blend out or again match the surrounding knots.
    You can tell a lot about a person by the jokes that offend them
