Results 1 to 10 of 22
Thread: Works Good, Lasts Long Time.....
    1,289
    Hey! These X-Stender's For Bessey K-Body Clamps really work great!
    http://www.ptreeusa.com/besseyK_body.htm (Scroll Down )
    At $15 it sure beats the stuffin' out of buying a $100+ clamp to get the right length.
    DT
    Tokiwadai, Japan
    2,882
    Great tool tip, Don. Thanks. That could solve a problem with "not enough long clamps"....
    Thanks for the report on these Don. I had my eye on them and will probably pick a couple up. Glad they work well.
    Odessa, Tx
    1,813
    That will work GOOD, "IF" you have the new Bessy's that have the hole in the end of the bar, but all of mine are the old style and will have to be drilled, and I'll bet that will be a real BEAR to drill in that super hard bar, whatchya tink? I have done something similar with my Jorgys and a home-made rig, (since the Jorgy's always had the hole). You're right that it is cost effective, especially since the really long ones aren't used all that much anyhow.
    688
    Thanks Don. Didn't know that product existed I'm headed for the shop now to see if I have holes
    535
    A cobalt bit might do the trick, then the only problem would be getting it in the right place!
    Punta Gorda, Florida
    902
    I didn't know about those either. Great solution. A few of those are going on my list.
    That's going to be one strong table base Don.
    Toronto, Ontario, CANADA
    2,332
    Thanks for the tip Don. I din't know about these either.
    About half my Bessey clamps have the required hole, so I will be able to use them.
    Cheers, Frank
    Constantine, MI
    8,015
    Count me in the "I didn't know these existed" group.
    Thanks Don!
    www.wrworkshop.com
    Sacramento CA
    102
    Hey Don, you forgot "don't rust, bust, collect dust."
  1. Long time lurker first time member
    By James may in forum Welcome and Introductions
    Last Post: 01-29-2016, 06:36 AM
  2. possible good news in the works
    Last Post: 03-29-2010, 09:51 PM
  3. After such a long time .......
    By Rob Keeble in forum Site Questions and Test Posts
    Last Post: 08-01-2009, 04:35 AM
  4. WOW! Works good, Lasts long time!
    By Don Taylor in forum New Tools
    Last Post: 12-10-2007, 07:47 PM
  5. Works Good, Lasts Long Time - Updated
    By Don Taylor in forum General Woodworking Q&A
    Last Post: 05-01-2007, 07:49 PM
