Results 1 to 3 of 3
Thread: Difference Between a Bowl Scraper and a Shear Scraper
    Jun 2012
    Laurinburg NC
    316
    Whats the difference between a bowl scraper and a shear scraper
    http://www.ebay.com/itm/Henry-Taylor...item2571d4d035
    Goodland, Kansas
    4,834
    Mike in my mind there is no difference. I use my bowl scraper flat on the rest or turn it at a 45* angle for shear scraping. So to me any bowl scraper can be used as a shear scraper.
    Bernie W.
    30,014
    Bernie pretty much nailed it, in my opinion. The only difference between a "shear scraper" and a regular ol' bowl scraper is the shape of the tip, and the only difference that makes is how you hold the handle when you're using it. (Typically, the handle on the shear scraper would be held lower than when doing the same cut with a bowl scraper.) In my opinion, they are mostly a way to sell people another thick scraper, not really a necessary tool in the arsenal for most turners.
    Keep in mind that the shape of any scraper can be changed in a few minutes with a grinder, so you can always tweak the shape if necessary. (I think most of us have two or three shapes we've settled on, but not all of mine are shaped the way they came from the factory.)
  1. Looking for Best Heavy Bowl turning Scraper Opinions !
    Last Post: 06-19-2012, 12:06 AM
  2. Which scraper to buy?
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 12-11-2009, 03:12 PM
  3. Negative Rake Scraper
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 01-09-2009, 02:00 AM
  4. Lathe tools - Bowl gouge and round nose scraper
    By Dawson Mossman in forum General Woodturning Q&A
    Last Post: 11-22-2008, 08:05 PM
  5. What a card...scraper
    By Alex Reid in forum Neander Tool Questions and Show & Tell
    Last Post: 03-05-2007, 02:36 PM
