Results 1 to 10 of 14
Thread: bird house for the fair
    Dec 2008
    falcon heights, minnesota
    5,606
    i got this one started today as well. only thing done so far is to plane the cherry down to 3/4".
    benedictione omnes bene
    www.burroviejowoodworking.com
    Dec 2008
    5,606
    all parts cut, fitted, and ready to be sanded and finished. i had to redesign the roof a bit.
    Dec 2008
    Santa Claus, In
    4,779
    Awful fancy birdhouse. You must have a upper class of birds you there.
    Jan 2011
    3,798
    I like the design, though I feel the perch is a little thick in relation to the opening...just my opi
    Dec 2008
    5,606
    it's what i had on hand ken.... lol
    Jul 2010
    Windsor, CT
    36
    Don't ya hate to plane down expensive wood to the desired thickness. What a waste of good, expensive wood. Occasionally I have to plane down three quarter red oak to one quarter thickness. Breaks my heart cause that stuff is expensive. Soft wood is getting expensive too. Birch plywood isn't cheap either. Ooff Da.
    Dec 2008
    5,606
    it wasn't too bad walter, this was made from odds and ends of previous projects.
    5,317
    Quote Originally Posted by Walter Mearkle View Post
    ...Occasionally I have to plane down three quarter red oak to one quarter thickness. Breaks my heart cause that stuff is expensive. Soft wood is getting expensive too. Birch plywood isn't cheap either. Ooff Da.
    That's where a bandsaw really shines! With a decently tuned saw, and a good blade, you can make that ĺ" piece into a quarter inch and a three-eighths piece, and have wood for two nice projects. I hardly ever take more than and eighth off of anything whithout using the bandsaw.
    Another alternative, if the stock isn't too wide, is a Japanese ripsaw (Ryoba). The pull stroke cut makes it easier to follow a line, and the kerf is amazingly small.
    Either way, you can cut your wasted wood by a huge amount.
    Dec 2008
    5,606
    that's what i did with the walnut and birch squares for the chess board jim, planed the boards flat (they were really rough), then ripped them down the thin side, then planed to thickness.
    Dec 2008
    5,606
    got a little more done on the birdhouse. i sanded and glued up the box part of it, and held off on the roof for a bit. as it sits now, it has been sanded, the roof glued on, and the oil applied. the shellac will start tomorrow.
    Attached Thumbnails Attached Thumbnails assembled and sanded.jpg   birdhouse oiled.jpg
  1. Composite bird house...
    By John Pollman in forum Flatwork Project Showcase
    Last Post: 08-22-2013, 02:38 PM
  2. Now This is a Bird House
    By Al Launier in forum General Woodworking Q&A
    Last Post: 03-19-2013, 06:16 PM
  3. Window Bird House - Nestbox
    By Daris Robertson in forum Flatwork Project Showcase
    Last Post: 01-14-2013, 02:52 PM
  4. Bird house bird suppliers??
    By Drew Watson in forum Off Topic Discussion
    Last Post: 01-08-2011, 11:09 PM
  5. BIGGER BIRD HOUSE
    By Paul Douglass in forum Lathe Project Showcase
    Last Post: 11-07-2010, 11:22 PM
