Results 1 to 10 of 22
Thread: moving my lathe out of the garage and into my spare bedroom?
    new york city burbs
    10,188
    is this a mistake?
    I havent touched my lathe in well over a year, maybe more like 2? not sure.
    Even though I have it mounted on a mobile table, I have to spin the table around and move all the other machines in the garage to access it, so I just dont.
    I have a small extra bedroom, that is currently my finish room,(but the room is hardly used as a finish room) not worried about dirtying or whatever in there, but Im concerned about getting dust and chips tracking throughout the entire house.
    The room has a brand new AC,naturally its heated, so I can try turning again,anytime, or should I say, start turning, during an evening, whenever, the noise wouldnt bother my wife whos upstairs.
    is this something Im going to regret? too messy for in home? Id clean up the mess each time I use it, as to avoid most of the dust going anywhere.
    anyone have a lathe in their homes? not garage or basement?
    Human Test Dummy
    Oct 2007
    Schenectady, NY
    912
    Allen,
    As you know, turning and sanding can be very dusty. I don't see a problem with the lathe in your spare room as long as you can keep the dust down for when you are finishing. I had 2 lathes in a bsement room that is about 10' x 12' and had a dust collector in there too. There was also my laundry folding table and a lot of my wife's storage. It was tight in there! But warm in the winter and cool in the summer.
    Don Orr
    Woodturners make the World go ROUND
    13,361
    If your wife lets you, do it!
    Jan 2011
    3,798
    That would be the cats meow IMO
    if your heating is forced air, you'd probably have to do something about the cold air return, dust-wise. Might also look into those self-adhesive draft sealer thingy's for use around the door jamb{s}...of course you'd also be closer to the frig which makes for tuff one handed gouge control
    12,260
    Dust would be my biggest concern. Given the amount of shavings and dust generated in turning and how hard it is too contain.
    Even with finishing in there. Allen you circulating the off gassing fumes with the forced air system.
    Sent from my MB860 using Tapatalk 2
    10,604
    A small portable DC would be your best friend. Plus one of these
    http://www.pennstateind.com/store/DLHOODC2.html
    It works very well.
    new york city burbs
    10,188
    there is no forced dry air heat. It is all hot water radiators(havent you guys seen all the radiator covers I made for my house? Am I not posting enough pictures?)
    bob, no intention of buying another dust collector and cluttering up the small room. The noise would make it an issue, and my daughter lives with us now during the school year, so Id rather not disturb her or my wife.
    my really only concern, is the dust and shavings.
    Its not like Im going to be turning chunks of wet wood all night long. Im thinking more along the lines of a bowl or pen every now and then.
    rob-Ive been finishing my furniture in my house for 2 years now, longer, counting my den area that I used to cover up and set up tables.
    I open windows and even at night, leave them open a bit with the locks on so fresh air circulates all the time, including the dead of the winter.
    Its only a few times a year Im using stains or poly, so its only a week or so at a time.
    (besides, Im beginning to use water based now and spraying in my garage, so I dont think Ill be doing much finishing in the house anymore)
    Human Test Dummy
    17,475
    well allen if it would make you more room in the shop i would go for it,, the dust from sanding could be controlled by a fan out a window to some extent. like aold furnace fan sucking it away from the lathe.. the chips would be just a dust pan job.. they do make small DC,s that could be used in your room to control things better
    Feb 2012
    2,749
    I would do this if my wife would give up one of the spare bedrooms. With the lathe I wouldn't have the problem of moving big pieces of wood downstairs, and the front basement bedroom has an electric baseboard heater. And dust? That's what shop vacs are for. It would allow me to do turning n the winter, which I can't do now.
    Cheers,
    Roger
    Jun 2007
    4,944
    Dust and chips from the lathe are my biggest problem in the shop. I tried a Big Gulp; it did not even begin to do the job. I have the PennState 2hp DC2000 B dust collector. It works fine on the other machinery and the lathe is tremendously better than before I installed this DC. However, I still get dust and a dirty floor. I wear a dust mask; in fact it is essential with the lathe.
    All of my ducting is 6 inch Sewer and Drain Schedule 35. My turns are gentle. I have a slight downward slope towards the DC proper. My ducts are all clean inside. The unit works. However, it just cannot handle the lathe properly.
    My concern is this. I cannot control the dust adequately with my 8 foot tall, 2 hp, 1 micron unit. Unless you have an even larger unit, you are going to have dust circulating into the house. Unless you seal the lathe room off completely and enter and exit from outside everyone is going to get dust into their lungs.
    This picky old goat is going to shut up now---I've probably said too much already anyway.
    Enjoy,
    JimB
    Yep! I did say too much. So I went back and deleted some stuff.
    Last edited by Jim C Bradley; 07-03-2012 at 04:09 AM. Reason: Removed unnecessary verbiage.
    VOTING MEMBER
  1. Buy Spare Belt for Jet 1642
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 10-26-2013, 01:27 PM
  2. Spare me a few of your thoughts
    Last Post: 05-04-2011, 03:55 PM
  3. Moving...Delta BS220LS and spare blades
    By Greg Cook in forum Old Ads
    Last Post: 12-13-2008, 05:38 AM
  4. moving a lathe
    By Bill Pealer in forum Off Topic Discussion
    Last Post: 01-30-2008, 02:29 PM
  5. Hey buddy, can you spare an aluminum?
    Last Post: 06-22-2007, 07:19 PM
