Results 1 to 10 of 23
Thread: Radial Arm Saw Station - With Fence
    13,360
    Finally got around to tuning up my radial arm saw to make dead square cuts.
    I also cleaned the bench off to the left of it and added a little cutoff fence.
    I put a 48" section of Kreg TopTrack along with a swing stop and some right to left reading adhesive measuring tape.
    Finally putting the old beast to work!
ID:	68621Click image for larger version.
    Constantine, MI
    7,890
    Nice job - looks a bit too clean through.
    www.wrworkshop.com
    13,438
    That works nicely. So does the fence extension come off and store? If so, what keeps it in alignment?
    13,360
    I've got some little screw feet on the bottom that allows me to adjust the fence to match the table. I then screwed it down at each end to keep it in alignment (Through the access holes you can see on the top).
    30,008
    Looks good. Glad to see you got 'er up and running square.
    Rennie, this the Brent we're talking about. Somehow I don't think the "clean" part will be for too long.
    13,360
    Merely cleared away for the pic, I assure you!
    Jan 2011
    3,798
    Looks great! When I first set my arm saw up I figured on just leaving it at 90°, throw the dado set on it & call it a day... nope, blade tracks showing up all over the top now
    I do need to set up a stop, like yours. Nicely done
    10,604
    Nice set up Brent I've been searching CL for a RAS so I can make up a station pretty much like yours.
    13,360
    Quote Originally Posted by Ken Cook View Post
    Well, I did make the top some 3/16 white faced hardboard. Once I start putting tracks across it it should be easy enough replace! And the fence, what that will be pretty easy to replace as well. I should probably make up a couple extra fences and just tuck them away somewhere.
    Thanks!
    Just got done using it and it worked like a champ. I almost feel like I have a real shop now. Prepping up some stock for another shop project and I was able to use the TS, RAS, Planer all with ease. Hot dang Tamale!
    17,471
    brent, your half done.. you are going to want a table to the right as well, one to support the longer stuff and also if your right handed you make a clean square cut slide to the stop on the right and cut to size.. i dont use mine for any angles just cut off at 90.. but wouldnt be without one..
  1. my new radial arm saw
    By keith Boutselis in forum General Woodworking Q&A
    Last Post: 03-07-2012, 04:22 PM
  2. Replies: 4
    Last Post: 07-08-2011, 04:34 AM
  3. My new Radial Arm Saw
    By Brent Dowell in forum Old Iron
    Last Post: 02-26-2010, 06:26 PM
  4. New TS Fence w/Router Fence Attachement
    By scott spencer in forum New Tools
    Last Post: 05-21-2009, 08:31 PM
  5. SOLD: TABLE SAW FENCE - SHOP FOX CLASSIC (fence only)
    By scott spencer in forum Old Ads
    Last Post: 05-12-2009, 05:18 PM
