Results 1 to 10 of 13
Thread: I hate small engines!
    Inside the Beltway
    2,666
    OK, so, long story short: The Derecho knocked out our power friday night. Saturday morning, I went down to start up the generator. I think the gas had sat in it too long. In any case, it didn't start. Took off the air cleaner: nothing. Put in a brand new spark plug, didn't help. Drained the bad gas, put in new. Still nothing. Added some degunker to the gas, let it sit. Nada.
    So I went to the autoparts store and got some Berryman. And some starter fluid. Came home, and tried the starter button. It ran a moment, and died. Encouraged, I started trying new things. Turns out as long as I spray starter fluid into the carburetor, it runs. That tells me it's getting air, and spark, and isn't seized up. But as soon as I stop spraying, it sputters and dies. If I let it sit for ten minutes, it starts, runs a few seconds, and dies. The carburetor has a drain screw, if I turn it, gas comes out, so I know gas is getting from the tank to at least the drain bowl on the carburetor.
    I'm completely stumped. Any ideas? I'd like to get it fixed before the next round of thunderstorms knock us out again...
    Bill
    13,360
    I've had this happen on my small engines that sat too long with fuel in the carb. I've fixed it before by taking the carb apart and make sure it was degunked.
    But, it's easy to screw it up. One time I lost the needle valve seat and had to order a new one. Last time I just capitulated and took the chipper shredder in to the small engine dealer.
    This guys video shows it pretty well. http://www.youtube.com/watch?v=pw7tlsEMn2c
    I agree with Brent.....you aren't getting enough gas from the carberator to the cylinders. Most likely, the passages from the carberator to the intake manifold are gunked up.
    Once you get it running, running it for 5-10 minutes each month will help prevent that.
    Ken
    Oct 2009
    Near Gassaway,West Virginia
    105
    Check the fuel filter, sounds like it may be gunked up.
    Fred
    steercreekwood.com
    I agree with the above and thanks for reminding me to run the generator this coming week end been a few months.
    Biggest problem with generators and anything with a small engine is sitting up unused for a long time with fuel in the carb, it turns to varnish and gets yucky. Seafoam in the gas usually cleans it up just fine. Next time shut off the fuel and run the carb dry and eliminate those problems. I have a small generator that is 10 years old and I can go out there right now open the fuel cutoff and it will start 1st or 2nd pull and purr like a kitten. Also put Stabil in the fresh fuel it lengthens the storage life drastically. Good luck.
    Bob
    Making saw dust in SW Louisiana
    Jan 2011
    3,798
    Sounds like the fuel pump/diaphragm...rebuild the carb scenario...they're actually pretty easy, most carb kits come with a basic manual type page to follow, worse part is, other than forgetting where things go or losing parts is the tight quarters getting the carb off & back on....
    13,442
    I'd probably say it is the carb, but you might also gauge the gap on the plug. Had similar problems for the past few times trying to run my blower for more than a few minutes. It would get warmed up and stop working. Finally cleaned and gauged the plug and it's been running fine since.
    12,251
    You guys must get pretty bad gas, i have weed eater and lawnmower and leave them from Nov thru to May and pull them out and they start first time with gas being left in all that time. These units are 10 years old. Never touched a plug or anything on them and my sons have been the users so only lost parts they can fiddle with like bolts.
    10,604
    The guy I just bought my new used JD tractor from, owns a small engine repair business, said that the ethanol in gas is the culprit. He told me to use the Stabil fuel stabilizer that comes in the blue, not red, bottle and that will take care of the starting problems and carb varnishing. The ethanol even corrodes the fuel lines.
  1. Hand Carved Engines and other Automotive Art
    By David Agnew in forum General Woodworking Q&A
    Last Post: 01-25-2013, 07:34 PM
  2. Engines Animated!
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 11-22-2012, 06:10 PM
  3. Don't you hate it when.....
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 10-01-2009, 12:49 PM
  4. Hate to tell you this
    By Howard Wilson in forum Off Topic Discussion
    Last Post: 01-14-2009, 12:32 AM
  5. I hate red x's
    By Bruce Page in forum Off Topic Discussion
    Last Post: 08-17-2007, 07:15 PM
