Results 1 to 8 of 8
Thread: different bottle stopper ideas
    Dec 2008
    falcon heights, minnesota
    5,610
    i'll be posting more once i pry the ideas from that bucket of mush i call a brain, but i've got 2 ideas in the works....
    benedictione omnes bene
    www.burroviejowoodworking.com
    Jul 2007
    DSM, IA
    5,719
    Different shapes or different material for the stopper? I don't have an idea for either, but look forward to what everyone comes up with.
    My Website
    Dec 2008
    5,610
    ok guys, here are the two ideas, the first should be easy to figure out, for all of you golfers, and the other has just been started, but it involves 10 gauge shotgun hulls.
    The golf ball idea I think is a good one. Golfers will buy almost anything that seems differant.
    Dennis
    Dec 2008
    5,610
    finished the other 10 golf ball stoppers today. starting on the shotgun shell ones tomorrow.
    Dec 2008
    5,610
    finally got around to the shotgun shell stoppers today. hotter than all get out today (until the storms came through), and hotter in pop's garage. kinda hard to turn when you can feel it running down. oh well, i did manage to get one stopper done today. it is curly maple, and there will be 3 more of those, 4 in cocobolo, and 4 in padauk.
    Do you do any casting in acrylics??? If you don't you should. Then there would be thousands of ideas.You can cast different colors. You can cast things embedded such as dice and seashells and coins. You can do fishing stoppers. Too many to mention. Will look to see what else you come up with. By the way you did the golf ball, try a billiard ball. No not the 2-14" ones. You can get smaller ones on ebay.
    John T.
    Aug 2008
    Reno, Nv
    3,632
    I was just going to put up John's suggestion. A 3" long chunk of 1-1/2" PVC, you can cap or plug the bottom with your prefered meathod and mix away! The best results I get are from purposely over mixing a pen pour and dumping the left over in the PVC "mold". PR shrinks when it's dry so you can just smack it out on the bench or shoot some Pam in the mold...it won't react with the resin. Like John said...there are no limits...2 part pour, black on the bottom, let it cure. Get a bottle cap from your beverage of choice, set it on top of the black and then pour clear over the black and cap...Shazzam! Put in a bug, bee, fly, stone, Jell-o...whatever floats your boat. My brain just over loaded!
  1. first bottle stopper
    By Dan Noren in forum Lathe Project Showcase
    Last Post: 01-14-2010, 02:26 PM
  2. Bottle Stopper
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 12-02-2008, 03:43 AM
  3. Bottle Stopper
    Last Post: 11-02-2008, 03:54 PM
  4. My FIRST bottle stopper!!
    By Nancy Laird in forum Lathe Project Showcase
    Last Post: 04-17-2007, 06:10 AM
  5. 3-D Bottle Stopper
    By Bobby McCarley in forum Lathe Project Showcase
    Last Post: 03-18-2007, 12:43 AM
