Results 1 to 6 of 6
Thread: Panel doors question
    12,258
    Ok I am back in woodworking mode now the house is behind us and its quiet time for my business so i can get my mind around some woodworking once again.
    Now making a panel door i note that some use ply and some use wood.
    With wood i can see where the expansion and contraction means some space gotta be left in the slot and the use of the rubber ball whatchmacallits spacers.
    But the lastest edition of woodsmith/shop tips showed the guy doing a center cut on the table saw to fit a 1/4" piece of ply on the stiles and he made it a snug fit.
    Is this correct?
    I have noticed that the wood raised panel bits would make that edge that fits in the groove slightly angled so does that mean the slot is made to be a press fit on the edge given the expansion of a wood panel is going to be mostly pushing out towards the bottom of the slot.
    I am trying to brush up on my finer points and get em in my head once and for all. Getting a little tired just winging it and living with the consequences.
    I don't make ply panels fit what I would call snug. They fit "well" and I put a short line of glue in the middle of the slot in each rail and stile just because I don't like future rattles. I do not worry about movement very much with this construction but, I do allow a smidgen of room around the panel for the solid wood movement. Nothing scientific, I just don't make it fit like a glove.
    The Shopsmith method works very well if you want your panel centered and are using a stub tenon. I hardly ever do either. And the snug fit business depends on whether you are designing the panel to be structural or not.
    17,472
    ply panels are made to be close but not tight and glue cornerd or center.. solid panels 1/16 top and bottom and a 1/8 th on the sides depending the panel width..
    Austin, Texas
    1,448
    I'm with Larry. But it doesn't hurt to use space balls on plywood panels if they are loose enough to rattle.
    Charlie Plesums, Austin Texas
    17,472
    space balls are our friends for sure.. you can make your own with silicon caulk and cut into strips robs..
  1. Raised Panel Cabinet Doors
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 02-16-2015, 09:14 PM
  2. Six Panel Doors
    By Leo Voisine in forum Finishing School
    Last Post: 03-07-2014, 01:30 PM
  3. Frame and Panel Cabinet Doors Question
    Last Post: 06-27-2010, 05:25 PM
  4. Panel Thickness on Cab Doors
    By gary curtis in forum General Woodworking Q&A
    Last Post: 09-11-2007, 09:29 PM
  5. Question re: proportions for raised panel doors
    By John Kairys in forum General Woodworking Q&A
    Last Post: 01-16-2007, 02:32 AM
