Results 1 to 6 of 6
Thread: Two-speed drills
    Feb 2012
    2,746
    Question Two-speed drills
    I have two lovely Ryobi rechargeable drills, that both have two speed ranges. One range, obviously is slower than the other. I figured, less speed, more power, and tended to use the low range for larger spade bits. However, I was recently drilling 3/4" holes in spruce, and found that the work went faster at high speed (go figure!) The low speed is still too fast to be useful for driving screws. Also, I have a 4 speed drill press that I tend to leave on the second highest speed and just work away.
    So I wondered, are there any sort of guidelines for when to use high speed and when to use low speed when drilling material?
    Cheers,
    Roger
    Feb 2012
    2,746
    Thank you! That's very useful and complete. I'll have to put it on the wall near my drill press.
    Cheers,
    Roger
    11,825
    As shown there are a lot of guidelines.
    I keep my drill press at about 550 rpm and in nine years believe I have reset the speed less than six times. Works for me.
    On the rechargable hand drills I have the trigger is the main speed control for screws and such. My DeWalt does have a shifter. I have to admit using the trigger to control speed for screws is tricky. Batteries are shot for my B&D screwdriver and I miss it. Replacement batteries are more than the screwdriver cost new and I'm too stubborn to buy more.
    I have the same one in a plastic sleeve stuck to a metal surface near the DP with a magnet.
    You're welcome. I find the speeds a little bit on the aggressive side for the bigger bits. I have a 16-speed and tend to use 1 speed lower than recommended by the chart for big stuff... forstners mostly. My tinkering also involves a lot of metal, so I have a machinist's handbook listing for different speeds in different metals.
  1. Batteries for drills and other hand tools
    By Charlie Plesums in forum General Woodworking Q&A
    Last Post: 12-29-2012, 12:42 AM
  2. Chinese drill bit drills SQUARE holes
    By Brian McMillan in forum Off Topic Discussion
    Last Post: 10-11-2011, 03:51 PM
  3. 12V L-ion drills
    By Scott Hermodson in forum New Tools
    Last Post: 12-29-2010, 05:58 PM
  4. Li-ion drills
    Last Post: 10-24-2010, 06:16 PM
  5. Comparison review of seven lithium-ion drills
    By Cliff Holmes in forum New Tools
    Last Post: 12-16-2009, 11:22 PM
