Results 1 to 10 of 11
Thread: My new recond Bosch Jigsaw and the lessons it gave me.
    12,260
    As posted elsewhere i mentioned i had with the aid of some collaborators in Michigan picked up a recond Bosch Jig Saw on a super deal.
    Well as usual i got stuck into it without reading the manual and then when things did not go the way i had hoped well i went in search of a manual.
    I thought it worth sharing some of what i learnt.
    The bosch jig saw i bought is a Model 1587avs this has tooless blade change and variable speed, a dust blower and oscilation adjustment.
    First up i got done the project that it came in handy for. Thats a different story. It was a case of cutting baltic birch out.
    Even though i had bosch blades i had never done any research into blades period. My acquisition of Bosch blades had come about after hearing the comments about them from members here. Well the blade i bought made my fraudulent excuse for a jigsaw hand vibrator step up a notch but still a piece of junk remains just that. Going free to any member that wishes to pay for postage. I offered it to my buddy but he has three already and after he got to taste the Bosch lets say he now knows the difference too.
    Ok so first lesson i got was checking to see my base was set at 90 degrees if you want to cut edges that are square.
    My initial thought was something was wrong with the machine given it was recon.
    But i discovered that the aluminum casting on the base has a wedge shaped raised piece that helps to align the base perfectly at 90 degrees to the blade, that is if you take care to make sure to slide the base onto the wedge properly.
    But even after fixing this i thought something is up when i tried the two different type blades and put a square on them. One blade is thin and short T101AO and the other longer and wider.
    Thats when i decided to take the plastic non scratch insert out of the casting and look to see if there was some sort of burr or other manufacturing remnant that was causing the plastic to lift. Because when i put a straight edge across the surface side to side the surface was not flat.
    Well i discovered that the plastic insert had not been pressed in and clipped in properly even though it has 6 screws to hold it.
    When that was fixed and the based properly aligned on the wedge the cuts were unbelievable.
    Thats when the fun started. Up until then i was cutting a piece of Borg laminated scrap pine board 3/4 thick.
    I was trying out the T101AO blade which is amazing and in a machine like this Bosch well its another amazing on top of that.
    So i hauled out a square and got a piece of MI walnut a tad shy of 1 inch thick and keeping the narrow fine tooth blade cut a slice or two off the end of the walnut board.
    The finish and squareness of cut well i hope the pictures do it justice.
    Key thing i learnt is read manual. But then use your own senses and check out things when they dont seem to match what others are getting even if you a rookie.
    When i looked at the T101AO bosch blades and then took out the junkie vermont HD pack i had purchased 8 years ago there is just no comparison. One lot is stamped rubbish and the other is Swiss ground steel with properly ground and shapped blades.
    The T101AO has a taper from front to back on both sides which aids when it comes to cutting curves and keeping nice clean edges.
    It really really is worth having a selection of the blades on hand and switching them out for different tasks.
    My last point before pics is if you are on a tight budget and dont have money for a $300 upwards bandsaw get yourself a $99 reconditioned Bosch jig saw and a selection of blades and you will cut curves with fantastic edges on any wood. You may not be able to resaw but any other bandsaw job you would easily be able to do and the space saving is a no brainer.
Name:	Quality of cut2.jpg
ID:	68982Click image for larger version.
Name:	Quality of cut.jpg
ID:	68983Click image for larger version.
Name:	Plastic foot insert.jpg
ID:	68984Click image for larger version.
ID:	68985Click image for larger version.
Name:	1587 Bosch recond.jpg
    17,474
    yup a bump in the sole plate would cause unsquareness easily
    Independence, Kentucky
    1,355
    Well,. now Rob you can see why everyone that owns this saw sing's it's praises. I have had a recon for several years and going from B&D to Bosch was like walking into sunshine on a cold day. I use mine a lot.
    12,260
    Charles you make a good point. I had never thought of my jigsaw unless it was a absolutely only way out kinda deal. But with this baby i will certainly reach for it way more often. I could not believe how easy it was to cut straight and follow a line. With the right blade a bit of practice it could be an all round saw.
    13,451
    I grew up with the B&D jig saws. Avoided using it at all costs, would get out a hand key hole or coping saw before attempting to use a jig saw. A friend had an audio shop where he made boom boxes all day long and tried his out, wow...night and day difference. At that time they were around $600, so when the day came that I found mine for $150 I was ecstatic. Would buy another in a heartbeat.
    Good point on the selection of blades. I need to pickup a few various packs and give them a try. Have cut pieces up to 1 1/2" thick and gotten a bit out of square, I think a wider blade would have kept my cut square in that case.
    Indianapolis area
    1,697
    I found a good selection of blades on Amazon a couple of years ago. Now you understand why my Bosch saw is stored out of sight and when someone wants to borrow a jig saw I reach for the Craftsman that I keep just for that purpose.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    30,017
    Quote Originally Posted by Ron Jones View Post
    ... Now you understand why my Bosch saw is stored out of sight and when someone wants to borrow a jig saw I reach for the Craftsman that I keep just for that purpose.
    Similar story here...first person who asks to borrow a jig saw from me will get a used B&D to take home. And keep.
    4,699
    Rob you're making me regret my HF jigsaw...
    Well not really it was only $20 and as Vaughn noted its nice to have a loaner (last thing I loaned out was my palm sander, came back with holes worn in the sanding pad, what the heck!!).
    13,361
    How else to you expect them to get the sharp points off of the pointy end of a nail?
    4,699
    Sadly I could almost have sympathized with that, it was used to take the sharp edge off of a countertop and it looked like it had just been leaned on with no movement. About 80% of the sandpaper hadn't even been touched and the rest was gone right down through the pad to the metal plate.
    Yep loaners are nice to have.
  1. I finally gave in
    Last Post: 02-16-2012, 03:36 AM
  2. Bosch Colt and Bosch Jigsaw
    By Jim C Bradley in forum New Tools
    Last Post: 10-30-2007, 05:18 AM
  3. bosch jigsaw with free colt
    By tod evans in forum Hot Deals
    Last Post: 09-09-2007, 02:29 AM
  4. Bosch Jigsaw on deep sale at Amazon...
    By Greg Cook in forum Hot Deals
    Last Post: 07-07-2007, 04:59 PM
  5. Bosch Jigsaw (1587AVSP) $69.99
    By Tim Armstrong in forum Hot Deals
    Last Post: 03-01-2007, 06:13 AM
