Results 1 to 6 of 6
Thread: Freud 1700VCE router
    I have a Freud 1700VCE router and have always used a 1/2 inch collet. Now I have a need for a 1/4 inch collet but can't find it. I know I can buy one for $20, but that's a bit much for me. Did the router come with a 1/4 inch collet originally?
    Thanks, DKT
    Jan 2011
    3,798
    According to the owners manual, yes, it came with both...all I can offer... Manual
    Thank you, Thank you. After reading your reply I looked one more time and found it. Brand spanking new too.
    DKT
    17,471
    one suggestion dietrich,, when you use the 1/4 adapter make sure you tighten it down well.. some need to be aligned with the slots of the larger collet to get good compression.
    I'm not sure I understand your comment, this is a 1/4 inch collet, not an adapter. Looks just like the 1/2 inch collet only the size is 1/4 inch. But I do appreciate your comment, I used a CMT extension to rout a bowl once and the thing rattled loose. I'm more careful now when using the extension.
    DKT
    17,471
    didnt catch the collet part i was referring to a adapter,, sorry for leading you astray
  1. FS: Freud 5-piece Router Bit Set (NIB)
    By scott spencer in forum Old Ads
    Last Post: 01-02-2010, 12:48 PM
  2. Freud 45 degree router bit
    Last Post: 03-17-2009, 01:20 PM
  3. Replies: 10
    Last Post: 03-14-2008, 12:06 PM
  4. Freud Router
    By Al killian in forum New Tools
    Last Post: 01-09-2008, 10:22 AM
  5. Freud FT 1700 router
    By Dave Trask in forum New Tools
    Last Post: 04-18-2007, 08:18 AM
