Results 1 to 4 of 4
Thread: Chocolate cutting board, and cheeseboard complete with Holy face...
    Feb 2012
    2,749
    Back before Christmas, I was trying to make about ten cutting boards before December 25th, but trying to work in the ridiculously small space in the shed made that impossible, so I determined to finish them after Christmas, ASAP. However, on Epiphany, other events interfered (quadruple bypass) and I never got back to them until recently. I had bought two large pieces of Peruvian Walnut to make cutting boards for my son, a professional cook and manager, and my niece's husband, a good amateur cook. So, this is the board I made for my son. It is a single piece, 24" x 16", sanded through the grades down to 220, and finished with mineral oil.
Name:	fcutting board matt.jpg
    Now, a week or so ago, I decided to try some resawing. Never mind that I had a 3/8" 3tpi blade on my bandsaw, I figured I should be able to do it, therefore I did. I cut a 5" branch, cherry or walnut, I'm not sure, into " slices. I took the two middle pieces, and joined them together, to make a 12" x 6" cheeseboard. Interestingly, once it was joined, the face of a bearded man appeared. Now, I'm not much into silly miracles, and I don't think Jesus would come and visit my cheeseboard, but as I'm a member and Subdeacon of St. Barnabas Church, it could be St. B. Do you think I should put it in a shadow box at the church, and charge the faithful $5 to come and worship him? Or just use it for cutting cheddar?
    Now, seriously, folks. I do have a woodworking/finishing question. The board is finished in mineral oil at present, but there are some voids in the face of the thing where you see the dark coloured streaks runing the length of the board. Would it make sense to put multiple coats of a varathane type clear finish on it, until the voids are filled, and could I then use it as an actual cheeseboard?
    Cheers,
    Roger
    Jan 2011
    3,798
    I can't help on the finish, but I can say get that old man on flea-bay, you know what PT Barnum had to say
    Nicely done Roger!
    30,017
    Nice job on both boards, Roger. I especially like the big one.
    On the cheese board, the mineral oil is going to wreak havoc on any film finishes like polyurethane. The poly won't stick to the mineral oil. Others may have better suggestions, but I think I'd use naphtha or another strong solvent to remove as much of the mineral oil as possible, then spray it with a few coats of dewaxed shellac before applying the poly. (Dewaxed shellac is a miracle finish that adheres to almost any other finish.) The Zinsser Bullseye spray shellac at Home Depot or Lowe's is dewaxed.
    Sent from my iPhone using Tapatalk
    Feb 2012
    2,749
    Thanks, guys! I decided to just leave it oiled, and use it at home. My priest agreed there was a face in the board, but thought that making it St. Barnabas would be a pretty hard sell. Besides, we already have a Madonna and Child in the right panel of the organ, that mostly goes unnoticed.
    In other news, my son really liked his cutting board.
    Cheers,
    Roger
  1. Cutting plywood, good face up or down?
    By Jeff Bower in forum General Woodworking Q&A
    Last Post: 03-06-2014, 02:23 PM
  2. Cutting Board
    By randy street in forum Flatwork Project Showcase
    Last Post: 12-24-2009, 03:59 AM
  3. My First Cutting Board
    By Jeff Bower in forum Flatwork Project Showcase
    Last Post: 09-01-2009, 11:00 PM
  4. Cutting board
    By Jeff Horton in forum Flatwork Project Showcase
    Last Post: 11-17-2008, 04:39 PM
  5. Ulu cutting board
    By Bobby McCarley in forum Lathe Project Showcase
    Last Post: 02-09-2007, 05:31 PM
