Results 1 to 10 of 10
Thread: Different Style Circle Jig
    I made a different circle jig and it works really well. The center to center distance on the rods for the craftsman router that I have is 4".106. I used 8mm rods. The base is oak.
    Greg
    Attached Thumbnails Attached Thumbnails aluminum-bar-1.jpg   aluminum-bar2.jpg   aluminum-bar-3.jpg   Board.jpg   board-2.jpg
    12,264
    Greg you cannot be aware that idiots like me frequent this forum. Can you show us how this works i am lost. I can understand the build but how do i use it to make a circle? I have scratched and scratched and my brain still cannot get it. I am pretty sure it will be simple when you show how.
    5,323
    Thanks, Rob! I guess I'm not the only 'slow' one here, because I couldn't figure that one out either. I could see using the rods & bar as a fence, and also using the center pin/screw in the bar as a pivot, but I have no clue what the plywood piece is for.
    Help us dummies out, Greg!
    Indianapolis area
    1,697
    It appears that I'm in pretty good company when it comes to being "slow" on this one.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    Toronto, Canada
    276
    The bar is fixed to the ply and there is a range of adjustment on the rods. Move the pivot to the next hole in the ply as required.
    (Took me a couple of secs to get it) If you think this is ... I've got a couple of cirle jigs of my own ...
    5,323
    Quote Originally Posted by Ed Thomas View Post
    The bar is fixed to the ply and there is a range of adjustment on the rods. Move the pivot to the next hole in the ply as required...
    But then, what do you do with the ply? Does it pivot around a point/hole in the workpiece, or what? I can see using the center of the aluminum bar as a pivot point (center of the circle), but still don't see what the purpose of the plywood is.
    Toronto, Canada
    276
    ... but still don't see what the purpose of the plywood is.
    I'd guess it's an alternative to longer rods.
    Rob,
    The board has different holes in it for a pin to pivot on. It can do bigger circles while using the different placements for the pins and you can do all the between sizes by sliding the router down the rods. You measure from the edge of the cutter to the center of the pin and that is your circle size. The main purpose of the board is for adjustment of different sizes.
    Yes. With the different hole placement you only have to have one set of rods for the many sizes you can do. 2" to 15" circle can be done.
    Toronto, Canada
    276
    Thanks. Hadn't noticed that this also lets the pivot get closer to the bit for smaller circles. I had a jig about 30 years ago that used all-thread through the bar. Could do a +6' circle, but not smaller than about 8".
  1. butcher block style knife holder style..
    Last Post: 04-19-2013, 12:42 AM
  2. Circle Jig
    By Greg Brimer in forum Jigs and Fixtures
    Last Post: 06-24-2012, 01:42 AM
  3. Bandsaw Circle Jig v3
    Last Post: 07-25-2010, 05:01 PM
  4. Circle
    By Greg Cook in forum Site Questions and Test Posts
    Last Post: 01-03-2008, 08:35 AM
  5. A Different Twist on a Circle Jig
    By Sean Wright in forum Jigs and Fixtures
    Last Post: 05-26-2007, 08:55 PM
