Results 1 to 10 of 12
Thread: Air Compressor
    5,172
    Air Compressor
    Well, not a NEW tool but I don't know where else to post this.
    My air compressor is failing. Today it started popping its dedicated breaker. The breaker is new and the wire size is ample. The compressor was very well used when I first got it, maybe 20 years ago. I have rebuilt it once, about 8 years ago. Needed new reeds and general cleaning. It is an oil model. Can't GIVE me an oil less model. It is also the size of which is very difficult to find in an oil model. Complicated by the fact I do not want, nor need, a behemoth of a machine. The tank appears to be fine, I keep it drained but then it has always lived in a very dry climate. That helps.
    So. Choices. Replace the compressor head only? Might be doable from McMaster Carr or Enco, Try to find another model like it? Been watching CL for years. No joy. A new one has been illusive as well.
    Another complication is that I will be reducing my shop drastically in the near future. Some tools will be on the sale block. But I cannot imagine life without an air compressor. So size is an issue, and the old one is the right size.
    So tell me what else I should be considering.
    17,472
    well carol you havnt told us what size this one is that your looking to fix or replace..? kinda hard to make suggestions if we dont have the info on what you want
    30,017
    Dunno how their prices compare, but one other source for replacement heads is Eaton Compressor.
    http://www.eatoncompressor.com/page/page/518643.htm
    5,172
    Took a hard look just for Larry. It is Campbell Hausfeld 20 gallon tank with a Chicago Electric 2 HP dual voltage motor running on 110V. It lasted so long I thought it was better than that! It doesn't owe me a dime.
    What would you get to replace the whole thing?
    Jul 2007
    Florida Keys
    86
    I had a similar problem when my compressor died. So like you I thought I would replace the compressor on the old unit. Number one it takes some looking to find a compatible compressor to match your motor and existing sheaves to get the right rpms. Number two even though you can't believe it, a complete new unit will be cheaper than just replacing the compressor alone. I was dumfounded at this. So I did end up buying a new complete unit. Up side was that I now had a motor which now does other duties and a portable tank.
    17,472
    i agree with robert on this size of compressor carol,, keep looking on craigs list they come up frequently..
    30,017
    ...What would you get to replace the whole thing?
    I've been very happy with my big Eaton compressor. If my experience with Eaton is any indication, this one is probably good bang for the buck:
    http://www.eatoncompressor.com/catal...37/8749662.htm
    University Place, WA
    101
    Could be a pressure relief valve (that's the one that makes the his when you shut it off) is bad. If the head is still under pressure when starting it takes a lot more amps to start and could blow the breaker, especially on 110.
    Honolulu, Hawaii
    1,103
    I'm of a mind to be thinking "motor problem". I don't believe your comp. pump will be your problem, even if the reed valves and rings were bad. Those might make it run longer, but with less work for that motor. How hot does the motor get when you are running it? If it's getting too hot to put your hand on it, this may be your problem. More heat causes more amp draw. If (when) you replace the motor, try for a 220 volt unit. (Hopefully you can supply the higher voltage to the comp.) It just draws lower amperage to each circuit and general lower amp draw is usually less heating. Maybe you could even try the higher voltage on your present motor to see how that works.
    But, Carol, I really don't think your pump is the culprit, unless something is really wrong inside and it's beginning to seize up on you. My compressor is a 1921 DeVillbiss unit, on its third motor and still pumping strong and quietly too.
    Aloha.
    Ah,,,to live in Paradise!
    Registered voting member
    Oct 2009
    Near Gassaway,West Virginia
    105
    Carol I have to agree with Tony. The motor is probably the problem, could be a start capacitor or something very simple. A fix might be a lot less painful than to replace.
    Fred
    steercreekwood.com
  1. new compressor
    By Stephen Bellinger in forum New Tools
    Last Post: 12-27-2011, 03:57 PM
  2. Air Compressor............ Again......
    Last Post: 02-04-2010, 08:55 PM
  3. Compressor?
    By Rick Prosser in forum General Woodworking Q&A
    Last Post: 10-14-2009, 06:01 PM
  4. Compressor
    By Mike Rathe in forum New Tools
    Last Post: 01-30-2009, 05:30 AM
  5. Air Compressor
    By randy street in forum Hot Deals
    Last Post: 08-17-2008, 02:56 AM
