Results 1 to 4 of 4
Thread: A little update on my CNC ... work holding :)
    Sacramento, CA
    1,367
    So the last couple days I've been working on my work holding capability on my machine ...
    Here are a few pics of what I got done today ... the tracks for the vertical overhang:
    This should handle most of the long pieces.
    Then I started out on the triangle bits ... it's hard to describe just how much hardware is involved for each chunk of track ... each one gets 12 bolts so it won't flex no matter where I grab things:
ID:	69437Click image for larger version.
    And then mounting the triangle bits ...
ID:	69436Click image for larger version.
ID:	69440Click image for larger version.
    Notice that the board overhangs the rails some - this is my attempt at keeping some of the dust off those X rails. It may prove to be futile ... but it might work out. We'll see.
    So now I'm about ready to flatten. But before I do, I think I'll dial in the screws/steppers so that all the distances mach3 says to move are actually moving that distance. Once the top surface is flat, I'll work out ensuring each axis is square.
    Jason Beam
    Sacramento, CA
    12,256
    Jason i truly admire you and what you have done. You gotta be one of the rare breed of people that given time and money can basically do anything. Have you actually stopped to reflect on this ability. That machine is looking tremendous.
    I have question though, what grade of aluminum is the track. I ask because i used some t track in a router table and found that the bolts i used to secure things have over time had a negative impact on the track guide in the area where the head pulls up. When the need arises to clamp something down the aluminum gives and the next time that area is required it plays havoc with trying to tighten something down precisely in a only slightly different location.
    So i was wondering if this is going to happen to you with that track you have. ? I mean you gotta hold things tight for milling and precise milling at that.
    Sacramento, CA
    1,367
    Thank you for the compliments. I've been hearing that a lot lately ... to me, it's just like any other project: A series of small steps broken down and completed. I feel like the only thing I add to the mix is an obsessive personality that sticks with things quite a bit longer than other folks do.
    Very good point - I've run into that before myself. I'm not sure what the grade of this aluminum is, but in fastening the MDF triangles down, I used the track and a pair of clamps on each leg. I really cinched them down very tightly and I didn't notice any deformation in the slots thankfully. I used to have some of Rockler's blue 5/16" stuff and it would give me trouble like you describe pretty often.
    The track I used for the vertical overhang might give me that same fit. It's some bargain stuff from Peachtree and when driving the screws to mount them I was able to deform the area under the screw head pretty severely. I'll be keeping a close eye on that stuff. Thankfully it's easier to change than the stuff I have on top.
    Jason Beam
    Sacramento, CA
    13,448
    Nice work on the hold downs Jason. I wish I had done an overhang on mine, will do so on the next one. I've thought about adding some little brushes on each side to keep them swept off ahead of the carriage.
  1. Work holding systems
    By Carol Reed in forum New Systems and Builds
    Last Post: 10-08-2015, 01:47 AM
  2. Capn Eddie woodturning 101 Work holding
    By Rich Soby in forum General Woodturning Q&A
    Last Post: 09-19-2011, 12:50 AM
  3. Built in Storage - Work in Progress - Update #1
    By Gari Biasillo in forum Flatwork Project Showcase
    Last Post: 10-05-2008, 11:07 PM
  4. update of the project that I learned to never work as a subcontractor AGAIN!
    By Paul B Cresti in forum Flatwork Project Showcase
    Last Post: 03-02-2007, 09:02 PM
  5. This qualify as flat work update
    By Per Swenson in forum Flatwork Project Showcase
    Last Post: 02-04-2007, 04:58 PM
