Results 1 to 9 of 9
Thread: So easy.... yet took so long
    May 2009
    Lafayette, Indiana
    1,666
    I have learned something about myself.....everytime I "put off" a project, it's simply because I don't know what to do or how to get started.
    I bought one of these articulating arm lamps at a garage sale a few years ago. It was the kind that was made to set on a desk. Well the one I bought did not have the base, which was OK with me because I wanted to somehow mount it on a wall to use over my lathe. Today the light bulb (in my head) went off and I set out to get this thing mounted. I sat down with pencil and paper and drew up a plan that I thought would work and even wrote out detailed instructions for myself to follow. I went out to the shop and got started.
    Here is atutoriall on how I did it: Cut a block of wood....drill a hole in it....screw it to the wall.
    That's it....three years waiting for an idea on how to mount this thing and thats all it took. I don't know whether to be proud or ashamed.
    Anyway. I thought I would pass this along because it actually works quite well and I see these lamps at sales all the time for less than $1.00. Mine was $0.50.
Name:	100_0832 (Small).JPG
ID:	69480 I cut it out of a piece of 2x6 I had laying in the shop
Name:	100_0834 (Small).JPG
ID:	69481 I drilled a 3/4 inch hole and inserted a brass bushing
Name:	100_0838 (Small).JPG
ID:	69482 I screwed it to the wall and set the lamp into bushing
Name:	100_0835 (Small).JPG
ID:	69483 Lamp will swivel and lift up and down
Name:	100_0837 (Small).JPG
ID:	69484 This will make a great light over my lathe
    Feb 2012
    central florida
    194
    Wait.
    Ok. First. great idea! I have two of those with bases but I need to use one in an area where I can't attach the base so your idea is great.
    second. 3 YEARS!
    Jun 2007
    3,233
    Well, third. I had three articulated lamps some time ago. I gave them all away, two of them to patients, the other to a friend. Wish I had the two back.
    Well that last sentence kills my image as a charitable giver.
    The lamp will really help you with the lathe. Speaking of the lathe; what are the 7 wooden tools in the upper right part of the pic?
    I don't call my lathe dirty. However, yours is squeaky clean!!! I clean mine regularly, there is no rust, paint, nicks, etc. I even think Glenn would call it clean. However, compared to yours it is dirty.
    Enjoy,
    JimB
    VOTING MEMBER
    7,718
    Nice solution Tom.
    Ħuʍop ǝpısdn sı ǝuoɥd ɹnoʎ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
    Jan 2011
    Michigan
    1,990
    Nicely done Tom!
    Is it great minds think alike, or is it just due to old eyes I mounted mine on a swivel so I can use the magnifying glass when horsing out slivers
    7,701
    It's wonderful when an "eureka" moment finally dawns
    Asking a stupid question is better than repairing a stupid mistake.
    Sep 2007
    Plainwell, Michigan
    3,656
    Some times the easiest ideas are the best ideas
    May 2009
    Lafayette, Indiana
    1,666
    Quote Originally Posted by Jim C Bradley View Post
    Enjoy,
    JimB
    Jim, my lathe usually isnt that clean either. I usually have it sitting on another bench however now that I have this handy, dandy light. I moved it over to the work bench where I'll have a better set-up. The wooden parts you see in the picture are wine bottle holders that I have made for an up coming craft booth that I do each year. These are easy to make with little cost so I thought I would make a few of them to sell. Mine are a little different from the photo but work the same.
    SoCal and/or NM
    22,996
    That looks like it'll work great, Tom. The brass bushing is a nice extra touch.
    Years ago I had a similar lamp missing the base. I ended up just drilling a hole in the desk to accept the stem part of the lamp, and it worked well for years.
