Results 1 to 4 of 4
Thread: Around the House "Degreaser" for Lathe
    Jun 2012
    Laurinburg NC
    316
    Ok I just got the new lathe earlier in week. I wiped it down pretty good but I want to make sure all that " gooey stuff" (whatever it is called) they put on it when shipping is gone. Is there anything I can use around the house to clean it up good? I may not be able to get away today. I have some bioshield 9 I can put on it after it is cleaned up good.
    13,353
    I've used mineral spirits in the past to good effect. Make sure you show us your new lathe!
    5,317
    Kerosene also works well.
    Whatever solvent you use, be careful with the used rags. They can be a fire hazard!
    30,002
    Another vote for mineral spirits, but just about any handy solvent will do the trick. And I'll echo Jim's caution about the used rags.
    After it's clean, I just use Johnson paste wax to keep the rust at bay.
  1. "Small" house - Impressions, opinions, thoughts - all welcome
    By Rennie Heuer in forum Carpentry and Construction
    Last Post: 05-15-2015, 01:08 PM
  2. Found this on Cragslist "Vega Lathe"
    By Jay Caughron in forum Hot Deals
    Last Post: 08-15-2014, 02:16 PM
  3. Organizing the "Bunk House"
    Last Post: 12-21-2010, 02:03 AM
  4. Having trouble fing a good "used" lathe.
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 06-03-2009, 06:07 PM
  5. Shana's new "house"
    By Jim DeLaney in forum Flatwork Project Showcase
    Last Post: 02-24-2009, 04:15 AM
