Results 1 to 6 of 6
Thread: Cigar box piezo help
    Jan 2011
    3,798
    Since I haven't found the 'Electrical' sub-forum thought I'd ask here. I'm slapping together a homemade {cigar box type} geetar and I'm planning on using a Piezo or two for some added excitement However, this is totally new ground to me and I would appreciate any of you electrimagicians offering some help.
    The local radio shack didn't have the piezo I was looking for, so I ended up taking a 12vdc one they did have{$3.00, no great loss if it's useless for my plan}..eeenyway's, I'm at a loss on bypassing the circuit board and soldering direct to the element/transducer. Here's a photo of what I bought, followed by my question...can I tie-in/solder #1 & 2 to #3 eliminating the board{& of course #4 ground to the black lead? I've never encountered the ceramic part with the divided area{for lack of proper terminology } it's the same sort of confusion I'm having with this element{3rd photo} I raided from an old smoke alarm...can I use these types in this situation?
ID:	69678 Click image for larger version.
    12,264
    Ken my understanding of piezo is the output voltage comes from the two faces when the crystal is disrtorted. The middle connection as in no 2 i have not seen before ever but i would guess it has something to do with some sort of bias voltage to have the piezo operate in different modes. So if that was a buzzer i can see a dc bias being place on #2 and making it change its pitch or allow pitch to be set. Difference is in that case the device is used to output sound as a result of signal applied in your case you want it to act as a pick up. I would just leave #2 unconnected for your application.
    Jan 2011
    3,798
    Thanks Rob, I'll give that a test-see as I'm waiting for the local guitar shop to open...I think I'm going to grab a single coil pick-up or a humbucker if he has any used or cheapish ones laying around. From what I've gathered a piezo doesn't benefit from a tone potentiometer, and with my playing, I can use all the help I can get and now is the time in the build to 'git-r-dun' design/location wise
    I was also thinking that if indeed I can make these piezo's work, I may just add in a 3 way switch, mount them along with the magnetic 'pup' and see what kind of monstrosity I can create. ...this is all hopefully leading to a future build of a more substantial/conventional{} instrument...Thanks again for the thoughts!
    4,553
    Hey Ken I have 10 of those kind of builds going on right now I can send you a piezo wired and ready to go if ya want. But really all you need to do is just use 1 and 4. Sandwich the piezo dic between some thin wood ( I just cut a thin strip off of what ever is laying around or use 1/16" ply) using some silicone (I like loctite goop) then just glue or silicone it on under the bridge area. They work GREAT.
    More info can be found on C.B.Gittys web site or the CBG forum
    A Turn N Time
    Frog Pond Guitars
    May 2009
    Lafayette, Indiana
    2,380
    Hey I got one of these projects going on also. Well...I got the box anyway. Thats about as far as I got. I'm looking forward to seeing the end results.
    Jan 2011
    3,798
    Hey Jay, thank you so much! I did pick-up a pick-up , single pole..what are the chances of the piezo's co-habitation with the magnetic pup? I'm sure the frequency's are probably at different ends of the field ...the plan is a piezo under the bridge & another near the last fret{under the box top} along with the single pole mounted maybe 3" or so in front of the bridge. My thoughts are to keep everything separate...piezo's to the jack, single pole to a vol. & tone pot then onto the jack... which if would work would allow all 3 to work in unison, hence the compatibility question....or maybe I need to incorporate a switch to utilize 'either' the piezo's 'or' the single pole...am I on the right track or headed for a derailment? T.I.A. for any thoughts/tips/public lashings etc...
    Edit: oops forgot to thank you Jay for the offer , appreciated but not necessary{I hope }
    & Tom, pix will follow sooner or later, I have no shame
  1. New Cigar Pen
    By Sean Wright in forum Lathe Project Showcase
    Last Post: 11-20-2009, 04:24 AM
  2. Cigar
    Last Post: 05-01-2009, 03:15 PM
  3. 1st Cigar
    By Ed Nelson in forum Lathe Project Showcase
    Last Post: 01-31-2008, 03:21 AM
  4. Have a Cigar...........
    Last Post: 11-17-2007, 06:01 PM
  5. Have a cigar................
    Last Post: 12-24-2006, 12:26 AM
