Results 1 to 10 of 10
Thread: cheap way to apply a formica type laminate
    Feb 2012
    central florida
    208
    I have some left over formica. I want to put it on the surface of a tool cabinet I am just finishing up for my shop. It isn't anything fancy but I want the top to be very durable as a large metal vice will be sitting on it from time to time.
    I normally use contact cement with very good results but I don't want to spend $20+ on a can for something so small.
    Any idea on what I can use instead?
    3,134
    Would a Qt. of contact cement do the job? It goes a long ways.
    Feb 2012
    central florida
    208
    I didn't see any quart cans. Only the larger ones. I think they were gallons. The top is 33" by 30".
    If I could find a quart I think it would work. Though when I have used contact cement it seemed to get used up pretty quick.
    May 2011
    So. Florida
    268
    The box stores, hardware stores, lumberyards, should have quarts of Weldwood solvent based contact cement.
    Feb 2012
    central florida
    208
    No quarts. I did see the tag for a quart and it was $15. I opted for a spray adhesive. it was locktite medium spray adhesive. My first attempt was a disaster. I ruined the piece of formica I had when I tried to peel off the corner that touched down in the wrong place. ripped it right off.
    sprayed another piece I had left over from something else and and got it in place correctly.
    GOOD BOND. cost me $8. I think I used much more than I needed as one can only did about 5 square feet but $8 was a good number for this project.
    Rochester
    846
    It's good to know that the spray stuff will do the trick.
    Got Wood?
    Feb 2012
    central florida
    208
    Quote Originally Posted by scott spencer View Post
    I was shocked how well it worked. In fact I suggest to anyone who is going to use it that you put on a light coat on a test piece and try it first to see how much you actually need. I think i used way more than I needed and could have had more than 1/2 a can left.
    3,134
    Quote Originally Posted by keith Boutselis View Post
    Did you lay something on the top ....strips of wood, electric cord anything to suspend the laminate above the top to align it & then starting in the middle start sliding out the strips & pressing the laminate into contact with the top surface working your way toward the outer edges as you go? Then using a J roller or using a block of wood & hammer press it down to final bond.
    Feb 2012
    central florida
    208
    Not the first time
    Its not like I hadn't done this before. I even had the dowels but figured I could just slap the formica into place. I was wrong.
    When i did the second attempt with my second piece I laid long dowels on the surface. I just used a rag and a lot of elbow grease but got an excellent bond.
    9,077
    I hate it when I KNOW the tips and tricks to make things easier or more likely to be a success and for whatever reason, I shortcut is anyway. I try to keep in mind that "there's no shortcut that leads anywhere I want to go". I keep a set of strips out of an old mini blind over the rafters for such things.
  1. Kitchen counter or formica type laminate tops and adhesive ..HELP...
    By Rob Keeble in forum Carpentry and Construction
    Last Post: 09-02-2011, 09:14 PM
  2. Questions before I apply finish
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 10-29-2009, 09:38 AM
  3. Formica on top of Formica
    By Leo Voisine in forum Carpentry and Construction
    Last Post: 06-30-2009, 12:31 AM
  4. tired of formica so!!!
    Last Post: 02-12-2009, 10:58 AM
  5. Renaissance Wax: Best way to apply?
    By Keith Palmer in forum General Woodturning Q&A
    Last Post: 12-13-2008, 02:21 AM
