Results 1 to 10 of 16
Thread: New plastic laminate on the counter tops
    5,172
    I need to replace my kitchen counter tops before the house sale closes. I have the plastic laminate and adhesive. Can I apply it over the old stuff or do I need to replace the substrate and start from scratch?
    3,134
    Carol you can strip the edges & back splash & sand the top laminate to give it some tooth & using the regular contact cement not the water based cement glue the ends on first & then the front Then the top & back splash.
    Water based cement doesn't work well to glue laminate to laminate, according to the installers I know.
    May 2011
    So. Florida
    268
    +1. I agree. You may have to remove your sink, depending on its type and how it was installed. If the current top is a "post formed" top, i.e., particle board core, rounded front edge, and integral backsplash, you won't be able to laminate it DIY, you'll have to replace it.
    Dec 2008
    Santa Claus, In
    4,779
    And me to the yep, you can do that, list.
    5,172
    Thanks, guys. That just made life easier. No post formed backsplash. There is a separate piece which I will remove all together. I plan on a row of 6" tile for the backsplash when the new laminate is down. I'll have to check my adhesive.
    But a few questions.
    Sand with what grit for 'tooth'?
    Which goes first, the edges or the top? Also, the outside corners are radius-ed. I am assuming the laminate will bend without heating or something.
    Lastly, the big counter is "L" shaped and has a miter cut in the laminate. I gather I need to repeat that? I got one 12' and two 8' pieces.
    May 2011
    So. Florida
    268
    If you're using a ROS, or a belt sander, a 50x -80x would work well.
    The ends first, then the front, then the top. Laminate comes in two popular sizes. For horizontal use...1/16"... like for countertops. For vertical use, 1/32". Many patterns and colors come in both thicknesses in order to get a match up. In many cases, the 1/32" will bend around a 3" radius fairly easy. If not, a warm up with a heat gun will work wonders. If you are stuck with 1/16" material, you can block sand the backside carefully to get it to bend without cracking.
    Yes, that is the usual way. But, some installers prefer to use a 90 degree seam because it's shorter. Actually, I like the miter cut myself. You can use a straightedge clamped to the underside to rout the cut with a flush trim router bit. I use a 6" wide piece of ĺ" plywood with a laminated edge as a straight edge. Ideally, if both pieces to be mitered can be clamped so as to permit a onetime pass at 45 degrees, the fit will be very good. Whatever happens to one side happens to the other, and they will mate. You could pre cut the laminate on a 45, leaving ľ" long. That way you aren't routing a lot of material at one time. Allow for the diameter of the bit when you do this.
    When you do cut your miters, mark both sheets where they are supposed to meet before you rout, so as to align them afterward. When checking both sheets for a fit, the edge can be back filed slightly to allow the edges to mate better. You may have to file on the mating edges to get a good fit. My suggestion for installing would be to apply one sheet, with a spacer, like a ľ" dowel about 8" from the seam. Do that with the second piece. You can use Ĺ" dowels on the rest of the sheet to keep the parts from making contact until you're ready to stick them down. Position both sheets, and very easy pull out the dowels and let the sheet touch down (in the middle of its length) but don't press it down. When the miter is lined up, touch down both mitered edges. You should have a small hump where the ľ" dowel was. Use that gap to force the two edges together. Then press the rest of the sheet down. If the fit was good in the beginning, you may only need what one ľ" dowel provided.
    Press down with your hands from the center out to the edges to get all the air out. Then you can use a "J" roller, or a block of wood and a hammer. A general tip...when both surfaces have been coated with solvent based contact cement, it will stink like heck. So, make sure the area is well ventilated, You could get quite light headed. Before applying the laminate, be sure to check all mating surfaces for any debris, as that will show as bumps when you are done. Also check the mitered edges for any glue that would keep them from mating.
    Dec 2008
    Santa Claus, In
    4,779
    Mike is right on track. Easy as pie.
    17,472
    yup mike didnt miss a lick on the instructrions!!
    May 2011
    So. Florida
    268
    Post deleted...no edits.
    17,472
    mike to stick up for carol she has alot on her plate right now so perhaps she hasnt got there yet.. cant speak for her but can stick up for her
    thanks for the response and info you gave her and others can benefit from it later on perhaps..
  1. Tops
    By John Daugherty in forum Lathe Project Showcase
    Last Post: 09-14-2015, 03:24 PM
  2. Kitchen counter or formica type laminate tops and adhesive ..HELP...
    By Rob Keeble in forum Carpentry and Construction
    Last Post: 09-02-2011, 09:14 PM
  3. Best way to cut a counter top
    By Howard Van Huis in forum General Woodworking Q&A
    Last Post: 12-03-2010, 06:40 PM
  4. Gluing Laminate counter top ** Project Finished!! **
    By Greg Cook in forum Carpentry and Construction
    Last Post: 02-13-2008, 02:01 AM
  5. looking for copper tops
    By bill walton in forum Flatwork Project Showcase
    Last Post: 02-01-2007, 01:00 AM
