Results 1 to 5 of 5
Thread: glue question?
    17,470
    glue question?
    if one had a thin strip of wood that was made to be flexible, think lumber scale and it cracked length wize what glue would be the best to put it back together? it would need to have some flexibilty.. does normal yelo glue have any flex in it?
    I don't know how much flex that strip of wood needs to have, but archery bows are glued together with epoxy.
    17,470
    thanks bruce,, the thing about it is it is going a different direction and only a thin area for glue? i know what you mean on bows but they are using a wider surface area??
    I guess you have two choices:
    1. Try some glues and see which works.
    2. Make a new strip. I just can't guess the outcome.
    On further reflection, one of the typical laminations in many bows is itself a laminated strip of maple called superflex actionwood, which is made by laminating 1/8" layers of maple and then sawing that piece at right angles to the original layers. That results in an extremely flexible piece that has joints in the direction that you describe.
    17,470
    well then we will give it some epoxy then and use it like it was new
  2. Glue question
    By Roger Tulk in forum General Woodworking Q&A
    Last Post: 11-17-2015, 10:33 PM
  3. Glue question
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 10-04-2015, 06:27 PM
  4. New Glue question
    By Royall Clark in forum General Woodworking Q&A
    Last Post: 11-04-2014, 10:09 AM
  5. Glue question
    Last Post: 02-03-2011, 05:08 PM
