Results 1 to 10 of 15
Thread: How to Drill Accurate Holes in a Cylinder or Flute ??????
    Jun 2012
    Laurinburg NC
    316
    I make flutes as a hobby. I use a drill press and have tried some different ways of placing the finger holes accurately in line on these flutes. It is so easy to get "off". I though about getting a bench top milling machine which some makers use but wish there was a cheaper way that was still accurate.. A bench top milling machine on the cheap is still $700 to $800 plus all the necessities.. (My drill press is not the best but works) Ive been looking at Craigslist and have actually posted an ad wanting to do a swap/trade for some things I have...some nice deer hunting stuff and some other odds and ends...Any ideas on the placement of these holes??? Thanks!
    You don't have to buy a milling machine to get an x-y table....
    I don't know how long a flute is, but will 9" of travel do ya? $124 + tax + shipping, straight from Grizzly:
    http://www.grizzly.com/products/5-1-...de-Table/H7979
    Their 12" travel model is only $132.
    Of course, these are Chinese made "precision" pieces, so your mileage definitely will vary. I'd not want to use these guys for precision drilling holes in pistons or multiple piecework that required repeatability in the fixturing... but they should be plenty workable for a wooden flute.
    If you REALLY want to go cheap, you can build a simple sliding table really easily. Hopefully your area has a good metal supply / welding supply store. Buy a 36" stick of acme threaded rod for $15-$20, a couple acme nuts for $5 each, and JB Weld everything to a wooden superstructure and TA-DA. Sliding Table.
    Dec 2008
    Santa Claus, In
    4,779
    That's what I was thinking as well. Just make the table move and not the bit.
    I think a guy could make something with some thread-all and maybe some channel or T track.
    13,361
    I just hope the CNC guys don't get ahold of this!
    I'd say get one of those cheap X/Y tables. I've got one for my DP and it comes in handy for all kinds of things.
    Only works well on small projects, but it does do a good job of helping me get more accurately placed holes.
    new york city burbs
    10,188
    I would think something along the lines like making a fluted column.
    Secure the cylinder between to points, then build a jig to hold a plunge router and slide the router down the jig and put the holes where you need them
    Human Test Dummy
    4,699
    I was thinking a V cut lengthwise in a board, clamp the flute into the V and then slide along a fence. That should center it along the way.
    San Antonio, Texas
    765
    I use one of these for drilling cylinders, but I'm not sure it is what you are talking about.
    Billy B.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    NH
    4,005
    +1 for any of the above.
    Stupid hurts.
    4,699
    Quote Originally Posted by Billy Burt View Post
    I was claiming a redneck homemade version of that - a picture is worth at least 50 words...
    S E Washington State
    3,777
    What kind of flutes are you making. I've done the Native American flutes and yes, that was the hardest part for me. I once thought of maybe trying to do the process backwards and drilling those holes first, while the blank was still a square, but then you would have the problem of the correct location of the holes as you shape the rest of the flute. I wonder how the Native Americans did it with no fancy tools.
    "We the People ......"
  1. Lining Up Holes on Flute !
    Last Post: 12-31-2013, 12:36 AM
  2. Chinese drill bit drills SQUARE holes
    By Brian McMillan in forum Off Topic Discussion
    Last Post: 10-11-2011, 03:51 PM
  3. Got to drill some square holes
    By Don Baer in forum General Woodworking Q&A
    Last Post: 08-03-2009, 03:38 AM
  4. I need to drill two parallel holes
    By Jim C Bradley in forum Turning Tool Questions and Show & Tell
    Last Post: 07-18-2009, 03:41 PM
  5. Drill-Press - accurate fence setting
    Last Post: 12-25-2007, 09:59 AM
