Results 1 to 8 of 8
Thread: Miter Spline Jig
    5,533
    Miter Spline Jig
    Built a quick and easy Miter Spline Jig out of 3/4 in borg ply. Nothing fancy, but the carrier (angled pieces) are at as close to a true 90° as I could get them.
ID:	69764Click image for larger version.
    -Ned
    San Antonio, Texas
    765
    That'll certainly get the job done, Ned.
    Billy B.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    13,448
    Nice job on the jig Ned. What's the project it's going to be tested on?
    30,017
    Looks like it should do the trick, Ned.
    A suggestion: When you're not using your tablesaw, I'd recommend getting in the habit of retracting the blade. Leaving the blade up only invites dinged projects and skin, and risks damaging the blade, too.
    5,533
    Quote Originally Posted by Billy Burt View Post
    Thanks Billy, I'm sure hoping it will!
    Darren,
    I'm working on some skill-builders. Just a handful of small boxes. Nothing fancy, but they've been fun so far.
    Yeah, it was a Quick build... I cut the 45° on the plywood and secured it to the backer board in a span of 10 minutes max. I generally do drop the blade though, since the TS does serve as one of my main work surfaces.
    -Ned
    Jan 2011
    3,798
    Quote Originally Posted by Ned Bulken View Post
    .....the carrier (angled pieces) are at as close to a true 90° as I could get them.
    Not a necessity if you build like I do ...the old hippie in me keeps saying, "90's are for squares"
    Looks good Ned
    30,017
    ...Yeah, it was a Quick build... I cut the 45° on the plywood and secured it to the backer board in a span of 10 minutes max. I generally do drop the blade though, since the TS does serve as one of my main work surfaces.
    But in that 10 minutes you've already got clamps and workpieces on the saw top, just waiting to mix it up with a carbide tooth. Like you, I rely heavily on the saw table as one of my work surfaces, but my blade is almost always dropped before it's even done spinning after the last cut. I'm just in the habit of cranking the handle as soon as I hit the power switch. The only exception is if I'm doing something with an exact depth of cut. In those cases, I'll wait until I've confirmed the depth is what I need, then I retract the blade.
    5,533
    Couple of the boxes that are still works in progress...
ID:	69794Click image for larger version.
ID:	69795 Click image for larger version.
Name:	cherry maple box color.jpg
ID:	69796Click image for larger version.
Name:	sepia boxes.jpg
    trying out Lightroom right now, and these basically were processed entirely in LR4. Jury is still out, but it is quicker for adding photos to the computer as well as for keeping track of them.
    and one more for the photo fans...
    -Ned
  1. Poor Mans Dovetail Spline Jig
    By Roy Millsaps in forum Jigs and Fixtures
    Last Post: 10-29-2014, 03:15 PM
  2. Clever router based mitre spline jig does dovetails too
    By Rob Keeble in forum Jigs and Fixtures
    Last Post: 09-28-2014, 12:40 PM
  3. 4-way miter
    Last Post: 12-17-2013, 09:26 PM
  4. Miter Saw
    By Steve Southwood in forum Hot Deals
    Last Post: 05-23-2010, 05:31 PM
  5. Corner Spline Jig
    By Steve Ash in forum Jigs and Fixtures
    Last Post: 12-23-2006, 07:39 AM
