Results 1 to 10 of 15
Thread: Garage door seal
    17,470
    Garage door seal
    some time back someone had a problem with a garage door not keeping the rain out,, i have the same problem and i think they got a rubber piece that they glued down on the concrete and it stopped the leak does anyone remember the vendor or the person that used it.. i need to get one for my shop..Thanks for the help
    Constantine, MI
    7,888
    I think that was Allen.
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    30,008
    I know Harbor Freight sells the rubber garage door thresholds/seals. I've got one still new in the box in my garage. I'd send it to you if it wasn't on the other side of Arizona from me.
    17,470
    well maybe he will read this and give me his review of it because i am tired of having black tea come rolling in each rain storm..
    May 2010
    Orland Park, Illinois, USA
    278
    Larry, the bit orange box sells them ....
    http://www.homedepot.com/webapp/cata...gry=SEARCH+ALL
    Garage door seals do wear out... available at any "home center"
    http://www.lowes.com/Search=garage+d...d=10051&rpp=16
    As long as the concrete isn't cracked, spalled, or uneven, the door should keep water out just fine without any helper seals on the concrete. Your seal may be old and hard or the door opener (assuming automatic door) may need to be adjusted with more "down" force.
    One of my garage doors is at a low spot due to a section of driveway settling/sinking. During torrential rains, water pools against the door and once it hits about 4" deep, it would seep under. I replaced the 10-year-old door seal and set the opener "down" force 2 more clicks and haven't had a problem in two years since.
    edit - D'oh. Robert beat me.
    17,470
    my problem isnt age on the seal of the door its the no slope at the door entrance i need to make the water run away from the door and the track aera to get a better seal.. the crete guy seemed to forget to drop the door opening to have the water run off and is now flat and catches it all to run in..
    Oct 2007
    Nova Scotia, 45N 64W
    1,244
    Jackhammer?
    4,552
    I got mine from the door company Larry also make sure the put a seal around the out side of the door frame that made a big difference on mine and make sure to use a lot of sealer when installing it. DAMHINT
    A Turn N Time
    Frog Pond Guitars
    Floydada, Tx
    1,941
    My last shop was like that and broke out the crete and installed a crate so the water can drain down into a 3" sewer pipe and into the creek. This might be a option for you as you have that hill on the side of your shop.
  1. Garage door mahem
    Last Post: 04-20-2016, 01:54 AM
  2. Garage Door Break-in
    Last Post: 01-12-2016, 12:23 AM
  3. Garage Door Opener Installation
    Last Post: 01-21-2015, 03:50 PM
  4. Installing an Old one piece garage door
    By Ivan Coleman in forum Off Topic Discussion
    Last Post: 09-03-2014, 02:55 AM
  5. Garage Door intallation
    By Ivan Coleman in forum General Woodworking Q&A
    Last Post: 06-27-2014, 01:19 AM
