Results 1 to 2 of 2
Thread: How much clearance around an exterior door?
    5,533
    OK gang, fall is almost here and I'm gearing up to redo my door to the shop. How much clearance should I leave around the door? I'm thinking 1/4" max, with weatherstripping behind it, that sound about right to y'all?
    -Ned
    13,448
    1/8" on each side between the door and jamb. The rough opening I usually do at least 2" wider and probably an 1" taller for an exterior door to make room to square it.
  1. Wood for exterior door
    By Brian Corrigan in forum Carpentry and Construction
    Last Post: 08-09-2013, 01:18 PM
  2. Exterior glue question
    By Bob Gibson in forum General Woodworking Q&A
    Last Post: 05-24-2013, 03:30 PM
  3. Wood Type for Exterior
    By Sayer Fancher in forum General Woodworking Q&A
    Last Post: 11-21-2012, 12:28 PM
  4. Refinishing Exterior Oak Door
    By Lawrence Miller in forum Finishing School
    Last Post: 09-16-2010, 07:24 PM
  5. finish for walnut for exterior use
    By patrick anderson in forum Finishing School
    Last Post: 10-07-2007, 03:22 AM
