Results 1 to 10 of 12
Thread: Squeeky floor fix
    Tokiwadai, Japan
    2,882
    Squeeky floor fix
    I've got some squeeks in the floor in a few places (under carpet) and want to get rid of them.
    Does this really work?
    http://www.amazon.com/gp/product/B00...4196505&sr=8-1
    Or would a 1 1/2" finish nail, driven by an finish nailer and adjusted to go a bit further into the subfloor, do the same thing?
    Thanks.
    Odessa, Tx
    1,813
    Greg, a nail will always loosen up eventually if the two pieces of material are not fitted solidly together and there is any "give" to either of the pieces, whereas a screw will hold the two pieces tightly together. I remember a report over a year ago somewhere that said this system really worked exactly as advertised and whoever it was that used it was well pleased with it. Note: I have not personally used it, (concrete floors in our house), but I would sure be willing to try it if I had a need for it. I noticed the reviews seemed good on Amazon as well.
    Let us know how it works for you if you try it, (never know when I might have a need for it as well).
    London, Ontario
    3,383
    Greg, I've seen this used on a Canadian DIY show .... oh about 9 years ago. (The host had a reputation as a straight shooter, so I tend to trust him) So it has been around for a while. But I don't have any personal experience. I think I'd rather work from below, but if the basement ceiling is finished, then you don't have much choice, do you?
    Smithville, TX
    358
    The toughest part is finding the joist... When you know where that is a finish, or trim screw, will do the same thing. I have done this many times in my home and customers' homes... However, that kit certainly isn't expensive and seems to make finding the joist a bit of a breeze.
    Mini Max Tool Acquisition Mediator.
    "An old man to most kids and a young man to those who are dead."
    www.samantics2.com
    Floydada, Tx
    1,941
    Greg, On a different place. Someone used a pocket hole jig from underneath and went thru the joist. If you can this might work better as it will pull the floor tight again.
    Al
    Tokiwadai, Japan
    2,882
    Thanks for the comments.
    The only way to approach the problem is through the carpet into the sub-floor/joists (from the top).
    Our house appears to be a 2 story, but is actually a multi-level (6) with several stairs. There are no unfinished ceilings.
    I think I'll give it a try.
    2,784
    Greg, I can't tell if this is the same thing or not, but there was an episode of Ask This Old House where Tom Silva used something that looked like this. The screws would go in, then you snap them off just below the subsurface so that you couldn't feel anything walking on them even barefooted. He was sold on it, if this is indeed the same thing. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Baltimore, Mary land
    68
    It does work...
    Yes it does work. I have used these when doing a 1 year punch list for customers. One thing you have to watch is when you drive the screw, you don't grab any of the carpet strands because it can pull and unravel your carpet. I have also just driven 2 1/2 course drywall screws in, leaving about 3/4 of the head sticking up and snapping it off with my hammer. Most screws will snap below the surface if you can hit them back and forth enough. Once again you need to watch how it goes it, because you can do more damage then good if you put runs in the carpet.
    -George
    Monroeville, IN(Fort Wayne)
    111
    Greg
    I used one of those in our old house and it worked pretty good, if I had any idea where it might be now I would send it to you to use
    my goal in life is to be as good a person as my kids think i am
    life is short, even in it's longest days
    Tokiwadai, Japan
    2,882
    Good news... Thanks!
    It is the same unit that was on This Old House...according to their ads. Good to hear from others who have had success. I think I'll go ahead and get a set.
    Thanks for the offer Kevin. Amazon has the kit, with 50 screws for $21 plus shipping, and just the screws for $10 + S/H.
  1. RV floor
    By Chuck Thoits in forum Carpentry and Construction
    Last Post: 07-16-2014, 01:46 PM
  2. Four on the floor
    By Jim C Bradley in forum General Woodworking Q&A
    Last Post: 04-26-2013, 02:27 AM
  3. To floor or not to floor.....?
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 01-10-2011, 05:52 PM
  4. First floor
    By Al killian in forum Carpentry and Construction
    Last Post: 08-08-2009, 04:44 PM
  5. Best finish for floor
    By Al killian in forum Finishing School
    Last Post: 04-06-2008, 04:52 PM
