Results 1 to 4 of 4
Thread: Rear Wall Clearance for porch swing
    Have seen some great wooking projects on this site. I need help with determining how far from the rear wall to place the 8 foot high chain pivot point so a porch swing will not strike the wall. Can someone who has a swing measure what I should allow. Rather than building a swing, my task is coming up with a support system that will be cantileveled off the roof load bearing side wall using the tail piece of the truss for the 12 inch soffit. Hence, I'd like to keep the distance from the wall to a minimun for the swing load moment arm effect but don't want to be striking the wall. Thanks for your help!
    Jul 2007
    DSM, IA
    5,719
    Matt, first welcome to the Family. I wish I had an answer for you, but someone will come along soon enough to help you out.
    My Website
    5,318
    It's probably going to depend on who's using the swing.
    If it's Grandma, then 6~8 inches will likely do it.
    If it's the Grandkids, then 6 FEET won't be enough!
    Guess I'll need to find one that I can test and record some measurements.
  1. About time I get my rear in gear!!!
    By Tom Niemi in forum Giveaways, Contests, and Swaps
    Last Post: 11-27-2015, 03:38 PM
  2. Has it got that bad that.... a rear family matter
    Last Post: 08-03-2014, 09:28 PM
  3. Rear View Camera for Bob
    Last Post: 08-17-2012, 02:29 AM
  4. Sharon's custom porch swing...
    By Ken Fitzgerald in forum Flatwork Project Showcase
    Last Post: 07-06-2012, 12:17 PM
  5. Ash Porch Swing
    By Donald Stonecipher in forum Flatwork Project Showcase
    Last Post: 10-02-2009, 05:58 AM
