Results 1 to 5 of 5
Thread: planer guide rod lubrication?
    Honolulu, Hawaii
    1,103
    Hi Guys. I have a little Delta 12" lunchbox planer, and I have had to constantly clean rust off and wax the four upright guide rods on the planer.
    Question is, "What do you folks use to keep these guides clean and lubed?" And, "How often?"
    Note: we get plenty salt air here and even the cutter head gets rusty too. Cast iron tables are a commitment to keep from rusting.
    Thanks for any advice,
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    10,606
    I use a product called "top saver". I use it on my planer, ts, jointer, bs, and mortiser. It takes off the rust and leaves a slippery film that doesn't collect dust. I apply it about once a month.
    Honolulu, Hawaii
    1,103
    Sounds like that stuff may work better than wax. I'll have to get me some. Thanks for the reply. Aloha.
    Honolulu, Hawaii
    1,103
    I am going to highjack my own thread, but on the same machine.
    What do others do to keep the feed rollers gripping the wood and feeding smoothly and continuously? At times, mine literally stops and I have to pull the material along from the outfeed side, of course keeping my hands in the clear. Replacement rollers seem to be getting unobtainable, but my supplier is going to keep looking for me.
    In the meantime, what can I do to get the roller surfaces stickier? Any thoughts on maybe wrapping self adhesive sand sandpaper ( like would be done on a drum sander)?
    I am open to trying suggestions from the "family".
    Aloha, Tony
    Tony, I've had good luck cleaning the rubber feed rollers in my little Delta lunchbox planer with denatured alcohol. It tends to make them more "grippy".
  1. Hand sawing and lubrication.....mutton fat
    By Rob Keeble in forum Neander Woodworking Q&A
    Last Post: 04-11-2013, 06:18 PM
  2. Would you please guide me ?
    By Martin Roy in forum Finishing School
    Last Post: 04-18-2010, 04:31 AM
  3. Table saw gear lubrication...What do you use?
    By Jim O'Dell in forum General Woodworking Q&A
    Last Post: 03-16-2010, 06:59 PM
  4. Bandsaw Guide
    Last Post: 12-01-2007, 11:04 PM
  5. router plunge column lubrication recommendation
    By Darrin Wyatt in forum Old Iron
    Last Post: 07-21-2007, 07:49 PM
