Results 1 to 9 of 9
Thread: Delta 10" midi lathe motor
    San Antonio, Texas
    765
    I thought I'd pose this question to my fellow spinney folks. I have 2 older Delta midi lathes. One of them is fully functional and I use it regularly. The other has a bad motor. Delta has discontinued the replacement motors and I know that PSI makes a varialble speed replacement that will fit it, but I've heard it is under powered. I'd like to get the other Delta running so my grandkids can turn beside me (I have 2 who want to learn so far). And I'd like it to be variable speed. Have any of you heard of someone successfully replacing the motor with an option other than the PSI VS? I'm wondering how different the set up is for the newer Delta VS midi, or possibly a Jet VS mini and whehter or not I m ight be able to retrofit one of those motors. Any thoughts or success stories?
    Billy B.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    I have a Delta midi and replaced the motor with the PSI variable speed. Second usage and the controller burned out. Returned it to PSI (I paid shipping) and they replaced it. New unit burned out after third use on small bowl. Repeat process, new unit burned out after second use. Gave up on the PSI junk (shipping cost was accumulating).
    San Antonio, Texas
    765
    Dang, Joe! And I just had a fellow on IAP tell me that he upgraded both a Jet and Delta with the PSI VS and he couldn't be happier. I'm not sure if he does more than pens or small spindles, but I like turning small bowls and HFs on my smaller lathe. This leaves me even more perplexed. But I'll come up with something. I may just have to ask Delta if the motor for the new 12" midi will fit mine... or can be made to work.
    Billy B.
    Sorry it wasn't what you wanted to hear. I talked to the fellow at PSI (can't remember his name) very nice individual, but he said that he had to test all the controllers as they came in to weed out the defective units. Sounds like poor (or none) quality control from China. Anyway, after the fact I got the impression that the variable speed was really intended for very light duty like pen work.
    San Antonio, Texas
    765
    Well, I went and did it; ordered the PSI unit yesterday. And my functional Delta threw my last belt Friday so I had to order new belts that afternoon. Neither will be here until next week sometime. So I've continued to try and organize more more efficiency in my small two car garage. But I'd rather be turning!
    Billy B.
    lutefisk capitol, USA
    485
    I have seen the Delta mini fitted with an after market motor suspended below the lathe on a pivot. Gravity kept the tension on the belt. My Delta mini crapped the motor and I sent the whole lathe to someone. Can't remember who. I have the Delta variable speed and so far am happy.
    San Antonio, Texas
    765
    Dale, I think it was me that got your old one. Was it a 46-250? It now sports the PSI VS conversion. The new motor does seem underpowered, especially on lower speeds. I've actually bogged it down while sanding Friday. But I'll learn its limitations soon enough. To add to my frustration, the start capacitor on my LA 200 Midi went out Thursday. So I'll be saving up for a new Delta VS midi.
    Billy B.
    485
    I could swap you my Delta variable midi for your Powermatic. Save you the trouble of wiring your shop for 220. I'll even deliver it.
    San Antonio, Texas
    765
    Quote Originally Posted by Dale Johnson View Post
    I bet you would, Dale! But thanks for the offer. I think I'll keep the PM. Saving up to get it wired (that will come before a new Delta VA) and I can't wait to get back to it.
    Billy B.
  1. Delta LA200 midi lathe
    By Billy Burt in forum Turning Tool Questions and Show & Tell
    Last Post: 10-19-2012, 12:58 AM
  2. Midi Lathe/Stand setup... aka help me set up lathe land in my shop.
    By Ned Bulken in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2012, 06:41 PM
  3. Delta 46-460 Variable Speed Midi Lathe
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 03-05-2010, 05:18 AM
  4. Delta Midi lathe for sale
    By Dale Johnson in forum Old Ads
    Last Post: 03-07-2008, 08:52 PM
  5. Delta Midi Lathe
    By Billy Burt in forum Hot Deals
    Last Post: 03-06-2007, 04:03 PM
