Results 1 to 8 of 8
Thread: Plane Iron - Resetting Primary Bevel sans Grinder
    Howdy.
    I recently picked up a Miller Falls 22c (22" corrugated)... basically a Stanley 7c. The iron in it is severely cambered... about 1/16th. Not to open the cambered / non-cambered discussion, I want to re-grind this to a flat blade. I don't have a grinding wheel and this is waaaaay too much material to try to remove w/ 80-grit on glass.
    Does anyone have a suggestion of what to try? I've got files but none of them are fine files. I'm also leery of filing an edge so far away from my desired 25* that I end up spending hours on the 80-grit anyway.
    Jan 2012
    Gonzales, Louisiana
    115
    Do you have a belt sander? That's typically where I start on rehabing irons and chisels anyway.
    Just take it slow as to not overheat and change the temper.
    Mar 2012
    SW Minnesota
    159
    I agree with Tom, a belt sander is the way to go. I use a cheap sharpening guide to hold the iron at the proper angle. Another advantage is that I don't have as much trouble overheating the edge as when I used a grinder for shaping.
    Nope, no belt sander. All I have is a ROS and a little 1/4 sheet jiggle sander. I've been doing some thinking about just cutting some wood to the proper angle, strapping it all together, then just being careful with a file....
    Feb 2012
    2,746
    Stanley makes a set with a sharpening stone, oil and a bevel guide for about $12. You can rub the blade against the stone until it reaches the desired bevel. It takes a long time, and you'll probably get fed up and buy a used bench sander...
    Cheers,
    Roger
    Central NY State
    3,374
    I think your best bet is 80 grit and a honing guide. I have never used a file on a plane blade, I think it would be quite difficult to obtain a flat bevel.
    Stones will take way too long. I think you'll be surprised how quickly sandpaper will work.
    Honolulu, Hawaii
    1,103
    David, I agree with Ken on using the sandpaper method, but I think I would go to 100 grit "wet-or-dry" paper and use it with a water lube, (maybe a pump bottle spray). Ought to work fast enough. As Ken said, you "will" be surprised how quickly it will cut.
    I also agree with using the bevel guide holder (the one with the roller) as this helps you keep a consistant angle.
    Aloha.
    Ah,,,to live in Paradise!
    Registered voting member
    May 2011
    Cape Cod, Ma.
    1,553
    Ive used a mill file to get it close when I have picked up used planes and the blades are messed. Just take it slow, the file will remove a bulk of the material much quicker than sandpaper (in lieu of a belt sander of course) just follow the 25 degree bevel as close as you can with the file, even a stronger angle 28 + then when you hone you are honing the cutting edge and not the heel bringing you back to the 25 much quicker.
  1. plane iron trouble..
    By larry merlau in forum Neander Woodworking Q&A
    Last Post: 05-01-2010, 08:09 PM
  2. old plane iron?
    Last Post: 10-07-2009, 06:55 PM
  3. FS: Lie-Nielsen No. 4 Bench Plane, Iron **Sold**
    By Keith Starosta in forum Old Ads
    Last Post: 08-13-2008, 02:50 PM
  4. Is Lie Nielsen Plane a Bevel-up Model
    By gary curtis in forum New Tools
    Last Post: 04-24-2007, 09:31 PM
  5. FS: AMT Cast Iron Rabbet Plane
    By Doug Shepard in forum Old Ads
    Last Post: 01-20-2007, 09:14 PM
