Results 1 to 10 of 12
Thread: Paint Brush Cleaner
    S E Washington State
    3,777
    Paint Brush Cleaner
    I'm not sure this is in the correct forum but I will give it a try. I like good paint brushes and I like to take care of them. Been doing some deck painting recently. It got me to thinking. Are there any good paint brush cleaner available? I clean my brushes well after every use but there is still a build up of paint just under the handle, top of the bristles I'd like to get rid of. Several years ago I bought some brush cleaner and it worker great for cleaning the old dry stuff and acted like it "reconditioned" my brushes. Doesn't look like what I used before is available anymore. Maybe I just don't remember the name, I searched and nothing that came up look familiar. Anyone use one that they would recomment?
    "We the People ......"
    Oct 2009
    Harrisburg, NC
    140
    It is not a cleaner but it helps a lot for prevention.
    Before you start, dip the brush in whatever thinner (water, mineral spirits, etc) you are using to the top of the ferrule and let it soak in. Shake or drain of course but the area under the ferrule will remain pretty wet. This will keep the paint/finish from wicking up into that area and keep it clean.
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
    3,777
    Thank you, Mike. good tip and I will give it a try as soon as I get them cleaned up good.
    3,132
    Paul the pro's around here that use top brand brushes,use both wire brushes,and paint brush combs. I have both and they work real well. you can buy them at any paint suppler,and for the little bit they cost there more than worth it.
    3,777
    Thank you. I have always used a wire brush when I clean and it does great on the few outer rows of bristles but I have a build up more inside. I wonder is a comb helps in there. Maybe I'll pick one up. I picked up some brush cleaner at HD today and have one of my brushes soaking in it to see what it does. If it works as well as the stuff I use to have I'll be real happy. It sure is nasty smelling stuff!
    3,132
    Paul yes the combs work real good getting in side and getting the stuff out. As far as the cleaner not sure of that, but i don't think i'd put my Prudys or wosters in some thing i wasn't sure of.As you know at 25 to 30 dollars each, i hate to take chances.
    13,353
    Well, I have a purdy brush that got a little gunked up. Used it on latex, and then some poly, and well, it was kind of stiff and unusable anymore.
    I know, Use the right brush and cleaner for the job, but whatever.
    So I bought some Brush Cleaner at HD and let the brush sit in there overnight.
    Used a brush comb on it today and I'll be darned if it didn't clean it up real good. It's now useable again.
    Soft and clean and ready to do work.
    The brush cleaner seems like it's just a mix of about every kind of solvent there is, so pretty nasty stuff.
    The good news is that it's pretty reuseable, so I bought a little blank quart can with a lid and us that to store it. Next time I need to clean a brush, I can just pop the lid off and soak the brush. I may never need to throw it out...
    3,777
    Brent, I bought the same thing right after I started this thread. It does work, although not as well as I "think" I remember the cleaner I used years ago. Another way I have revived a brush is to soak it in paint stripper. But talk about nasty stuff! I still haven't purchased one of those brush combs yet. I surely well next spring when I proceed to do the underneath of the deck.
    13,427
    The pro painter at my old work used to put his built up brushes in acetone overnight, then hit them with a wire brush. He had been using some of the same brushes for 5-10 years. I've used the same stuff that Brent posted, and had success too.
    I usually clean mine well, but a trick my aunt taught me (she used to do acrylic art painting) was to put a drop or two of dish wash detergent on the brush, work it in, squeeze out any excess/shape to a point, and let it dry with the soap in in. The soap helps keep any left-over paint residue from sticking the bristles together. Just do a quick rinse before you use it again and you're good to go.
    13,353
    Looking at the ingredient list, that brush cleaner has a little of everything in it. The mad scientist in me thinks I could have made my own from my collection of solvents I have around the house.
    Acetone, Paint Thinner, MEK, Etc.... MWUwahahahahahahahaha....
  1. Tool cleaner
    Last Post: 06-21-2012, 05:37 AM
  2. Air Cleaner remote problem
    Last Post: 05-17-2012, 04:56 PM
  3. Air Cleaner for Swap (07946)
    By Jim Mattheiss in forum Old Ads
    Last Post: 09-28-2010, 02:58 AM
  4. G0513X - Quieter and Cleaner
    Last Post: 05-17-2009, 04:33 AM
  5. Blade Cleaner - CMT Orange vs T.S.P.
    By Bryan Cowing in forum General Woodworking Q&A
    Last Post: 07-10-2007, 01:39 PM
