Results 1 to 4 of 4
Thread: cityscape in wood
    5,533
    cityscape in wood
    I was trimming the cutting board blanks today... and each time I got to the 'end' cut on the blank, I would stack the scraps up on the jointer (it was handy)...
    That caught my eye... so I shot another angle on it
Name:	cutoff bokeh.jpg
    that led to a bit of re-arranging:
Name:	sepia sculpture layout.jpg
    a bit of TBIII, a few clamps and I have this:
Name:	sculpture in progress.jpg
    another view...
    still a work in progress, but It reminds me a bit of a cityscape.
    Lori says I should put a finish on it, and put it in the gallery where my daughter in law works. (Her father is the curator)
    -Ned
    Dec 2008
    falcon heights, minnesota
    5,609
    ned, when my youngest nephew was quite a bit younger (around 6-8), he asked if he could play with some of my off cuts. sure enough, i checked after he had been quiet for over an hour, and found that he had arranged them in the laundry room, along the seam lines of the tiles. i asked him what he had going on, and he said it was a city.
    benedictione omnes bene
    www.burroviejowoodworking.com
    5,533
    I liked it for the shadow play going on, the city aspect just makes a certain amount of sense. So did the nephew ever get back in the shop and build anything?
    -Ned
    Jun 2007
    4,944
    Ned,
    A hundred or so years ago I won a PSA photo contest with a black and white photo entitled, "Deserted City." It was made with a couple of the kids wood play blocks, a piece of dry tree limb and high contrast photo paper.
    I wonder if the negative is still around. If it is I may find it in a century or so.
    I enjoyed your sequence and your photographer's eye.
    Enjoy,
    JimB
    VOTING MEMBER
  1. Wood Bowl - Unknown Wood
    Last Post: 10-02-2011, 02:23 PM
  2. Replies: 12
    Last Post: 02-08-2011, 11:36 PM
  3. New wood stash and drying wood
    By Dave Black in forum General Woodworking Q&A
    Last Post: 10-25-2010, 09:53 PM
  4. Wood glorious wood .....( from the movie of Oliver Twist)
    Last Post: 11-09-2009, 10:30 PM
  5. wood screen door build - which wood should i use?
    By Mike Gager in forum Carpentry and Construction
    Last Post: 03-07-2009, 02:24 AM
