Results 1 to 6 of 6
Thread: Peppermill
    Goodland, Kansas
    4,834
    Peppermill
    Have a question for all you turners. I ordered 3 salt mills and made one. Nobody has bought it. They have told me no one wants a salt mill. They are the ceramic type from Woodcraft. Is there any reason these couldn't be used for peppermills? I looked them over and the only difference I can see is that one is ceramic and the other stainless steel. Otherwise they look the same. I just didn't want them to just sit there if nobody was going to buy them. All my peppermills have sold but the one lone salt mill just sits down there. Thanks.
    Bernie W.
    Aug 2012
    Rome GA
    15
    I would suggest trying some peppercorns and see what happens. I gave up on salt mills because they constantly leak fine salt on whatever they are placed on. I have had much better luck with salt cellars for the cooking area. I make one with a rotating lid held closed with a pair of rare earth magnets. For dining areas I make a salt shaker that is a classic pepper mill shape reduced in size by 40% using the readily available rubber stoppers and stainless steel tops. I hope this helps Jack Kerwood
    S E Washington State
    3,777
    I'd give it a try if I were you. It can't be for salt only because they have ceramic pepper mill mech. also. It may grind finer that the pepper mill, but it looks like they are adjustable for the grind.
    "We the People ......"
    Goodland, Kansas
    4,834
    Thanks. I thought I would give it a go and see. I even put a bag of gourmet salt with it along with a matching peppermill. Several just wanted to by the peppermill. Didn't want the salt so I think I am out of the salt mill business.
    Bernie W.
    Tellico Plains, Tennessee
    4,353
    Bernie,
    I don't know anything about the salt mills from Woodcraft, but I use the ceramic crush grind mechanisms for all of my pepper mills and I also advertise that they can be used for sea salt... I do sell a number of them that people tell me they are using for salt grinders.... from the looks of the pictures, I can't see why they wouldn't work as a pepper grinder... as suggested give it a try....
    Chuck
    Tellico Plains, TN
    Goodland, Kansas
    4,834
    Well I put one together this afternoon and it worked like a champ. Only one little problem. The adjustment screw on the top has a big S on it. But the good thing my wife wants a salt and peppermill for her brother and his wife. Then she suggested one for my brother and his wife. So guess it is a moot point now. Thank you to the LOML for the suggestion.
    Bernie W.
  1. Peppermill
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 11-22-2011, 10:10 PM
  2. Peppermill
    By Peter Lyon in forum General Woodturning Q&A
    Last Post: 09-23-2010, 01:21 AM
  3. First Peppermill
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 11-26-2009, 04:54 AM
  4. Another peppermill
    Last Post: 04-01-2009, 07:53 PM
  5. Peppermill #3
    Last Post: 02-08-2009, 01:33 AM
