Results 1 to 10 of 13
Thread: I'm looking at this older Jointer. Opinions?????
    May 2009
    Lafayette, Indiana
    2,380
    Been looking for something to replace my benchtop jointer that burned up a motor recently. This was listed today by an older man whom I spoke with on the phone. He is moving into a retierment center and must get rid of all his tools.
    http://tippecanoe.craigslist.org/tls/3269445411.html
    I could spend more but I kind of like the old machines too. He says it runs well and he just put new knifes on it this past winter but never used it after that.
    I may have figured out how to set this in my garage and not have to put it out in my small shop where I do not have room.
    17,475
    tom go with apprehension,, this jointer is a knock off of a older rockwell which was a good machine but that fence is wrong in the pictures something is way loose or broke there.. so go with caution..
    May 2009
    Lafayette, Indiana
    2,380
    Thanks Larry. Yes, I thought the fence looked odd as well. I may go look at it if it's still there on Sunday but I'm too busy until then. I'm not able to find and reference to this machine online yet.
    17,475
    i had found some near me that were better than that for another 50 bucks..
    May 2009
    Lafayette, Indiana
    2,380
    I dont have a problem spending more cash Larry. Although, I am pretty thrifty and try to save as much as I can ...when I can. I just tonight thought that I might be able to clear some space in my garage and set a larger jointer in there. I have learned to be patient when it comes to tool buying. I'll keep my eyes open and the right one will come along when the time is right.
    5,323
    As Larry said, it's a (probably) TaiChi knock-off of the old Delta/Rockwell model. They were good jointers, but that one looks to have had the fence broken and re-welded. You can sorta tell by the burn marks and rust on the back side of it.
    That, combined with the fairly heavy rust on the beds would make me take a pass on it. Keep looking - there are better ones out there.
    Central NY State
    3,374
    I wouldn't buy that one either. Same reasons as already said: made in Taiwan, lots of rust, and poor fence.
    FWIW, I've had a jointer with that kind of locking mechanism, and it did not work as well as the kind which hold the fence in the middle.
    Bargains may be had, but you still usually get what you pay for.
    May 2009
    Lafayette, Indiana
    2,380
    I think you are all correct on this. I'll be passing on this...... and the search continues.
    11,833
    Looks very similar to the old Delta I purchased for $50.00 a couple years ago. I bought it because it was, still is, in very good condition. This one does not look cared for at all.
    Can you not just replace the motor on yours? Unless you are a high production shop, the HF motors are very good deals. And, motors are often seen at flea markets and yard sales. I have about four extra motors kicking around under my benches.
    May 2009
    Lafayette, Indiana
    2,380
    Frank, I thought about that today and I might try rigging up a motor to see how that might work. If I like it then I would have to build a frame of somekind to hold it all in together.
    This jointer company is long out of buisness and getting an exact replacement motor is not going to happen.
  1. Pricing older equipment
    Last Post: 06-11-2012, 05:24 PM
  2. Older newbie from Michigan
    By Richard Petersen in forum Welcome and Introductions
    Last Post: 12-11-2011, 07:22 PM
  3. Older Radial Arm Saw Problem
    By Doug Miller in forum Old Iron
    Last Post: 07-20-2009, 07:23 PM
  4. WTB - Older version of Cutlist Plus
    By M Toupin in forum Old Ads
    Last Post: 01-23-2007, 08:48 PM
  5. How do you clean an older Disston Saw?
    By Tom Henry in forum Neander Woodworking Q&A
    Last Post: 01-11-2007, 03:08 AM
