Results 1 to 10 of 12
Thread: Min-Wax gel stain
    Apr 2009
    Outside the beltway
    5,250
    Min-Wax gel stain
    OK a quick lessen on the use of Min-Wax gel stains.
    Most of the stain is wasted because the initial application of stain will seal the wood and the remainder will just sit on top and dry and will need to be figgerously buffed off.
    So here what I do.
    When you are brushing on the stain have a bowl of lacquer thinner next to you. Dip[ your brush into the thinner and un-load most of it. Then dip a small amount of stain onto the tip of the brush. Work with the grain flat brush 1st and then thin , side ways, motion coating as much as you can on one side. { I do sides and front 1st and top last.
    Then with a good terri cloth rag that has been dipped in Lacquer thinner and let alone to air out a bit so it is not wet /wet rub out the side. If it is a small coffee table end table stain the whole piece before rubbing it out.
    The Lacquer thinner will help the penetration and drying time of the oil. And if you want to go darker you can retain in 2 hrs.
    Min-Wax stains and inner mixable. I like to mix a Jacobean Penetrating with a Mahogany gel about 2/3rds to 1/3rd to get a rich Mahogany tone.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Good stuff Dave. Thanks for sharing your experience.
    Apr 2009
    Outside the beltway
    5,250
    Glad I can help, the best thing about this after 6 hrs you can seal with lacquer and finish. But I recommend 24 hrs.
    10,600
    Good timing on the tip Dave. Just bought some today. Thanks
    Apr 2009
    Outside the beltway
    5,250
    Bob test it on a separate piece of wood. You can ajust the tone inner mixing.
    12,245
    Well Dave I have experienced exactly what you refer to in the waste with Min Wax gel stains. But i did find them a good stain for a beginner. It was way more controlable being in gel form. I think i will try out what you have said on a scrap piece with stains I have to get some practice in while the tip is current.
    I lack your eye for color so i have to rely on what the stain does or what i like rather than a clueless perception of a rich mahogany tone.
    Question....if after drying will one be able to put water base lacquer like Enduro over it or does one first have to put a shelac barrier?
    Apr 2009
    Outside the beltway
    5,250
    You will need either shelac or a Jacques sealer if you want to go airborne.
    Rob a good way to decide the correct color to mix in is get a staining wheel or just put the correct practice piece next to the color your matching up to each other. Look and see what tone is missing. It will be most likely green, red or yellow muster tone. Blue will get you a deeper brown .
    12,245
    Thanks for the tip. I have a shopping list after seeing you in action and one of the things i am definitely getting is that stain color wheel. I gotta get a few items from Joe Woodworker and i will get one of those wheels from him too.
    Apr 2009
    Outside the beltway
    5,250
    Rob ol boy, any progress ?
    12,245
    Getting round to it. Been to lv for some stuff gotta get on to Joewoodworker but been busy.
    Sent from my MB860 using Tapatalk 2
  1. Stain bleed out..
    Last Post: 02-25-2015, 11:46 PM
  2. Stain then assemble or assemble then stain?
    By David Agnew in forum Finishing School
    Last Post: 07-23-2014, 03:22 PM
  3. First time using red oak, how do i stain?
    By Zach Meissner in forum Finishing School
    Last Post: 06-05-2014, 04:16 PM
  4. Gel Stain ?
    By Bob Gibson in forum Finishing School
    Last Post: 10-14-2010, 02:10 PM
  5. stain VRS dye?
    Last Post: 12-23-2009, 08:37 PM
