Results 1 to 3 of 3
Thread: Spalted Cherry Panel (work in progress)
    Jul 2007
    DSM, IA
    5,719
    I missed out on a pretty good deal for an older Delta 6" jointer this past week and was feeling kinda down about it...thought I'd try my hand at doing it by hand. These two cherry slabs were cut by the chainsaw a few months ago and I thought they'd make a pretty panel together. They were pretty cupped and a bit twisted so I couldn't see resawing them. I wasn't sure how sharp the planes were either as it had been some time since I used them but both of my smoothers were still mighty sharp! I got one side the thickness I want and the other side is close but once that is a bit closer it will be ready for glue up after I trim the ends square on the table saw. No idea what I'll use this for either, but it's been fun! The second pic shows what the second slab's thickness looked like just before I started on it.
    My Website
    17,470
    i can see the signs of healing jeff i think we can get you completely rehabilitated if you will just continue on this new regime
    Central NY State
    3,374
    Looking good there sir, and when you use a plane, there's no limit to the width of the board you can flatten...
  1. Spalted maple HF in progress
    By michael james in forum Lathe Project Showcase
    Last Post: 03-05-2011, 11:24 PM
  2. work in progress
    By tom cullom jr in forum Shop Tours
    Last Post: 02-10-2008, 04:51 AM
  3. A Work In Progress
    By Robert Farmer in forum Shop Tours
    Last Post: 08-03-2007, 06:52 PM
  4. Work in progress?
    By Matt Dunlap in forum Shop Tours
    Last Post: 03-05-2007, 02:17 AM
  5. a work in progress
    By ken werner in forum Flatwork Project Showcase
    Last Post: 12-28-2006, 10:40 PM
