Ken pretty much nailed it, action height, but you should be able to play slide and still finger the frets as it's setup now, just don't push down with the slide to the point the strings are hitting the frets. If you are and you're still being careful not to, then raising the bridge height only should buy you a little room. Mostly you don't want to raise it so high that it throws the pitch off when fretting.
