Results 1 to 5 of 5
Thread: Replacing kitchen countertop
    May 2009
    Lafayette, Indiana
    2,380
    Well, I opened my big mouth and now I have a project. It all started when we noticed that our kitchen faucet is dripping again. This faucet was here when we bought the house 12 years ago and it goes through rubber seals like every other year. So I suggested we just replace it and the sink. The countertop is also outdated so this would be the right time to replace it as well. Now when I suggested we do this I had assumed we would hire this work out to a contractor but now I think I'm just going to do it myself. My only concern is one section of the countertop is an "L" shape which means joining the two 45 degree miter cuts together. I will order the countertops to the correct lengths with the sink hole cut and the 45 degree cuts already done. My only concern is getting the joint good and tight for a near seemless look. I know I will still be able to see the seam I'm just concerned about getting it good and flat and straight.
    So I just use Titebond glue for this joint? Anyone have tips to help me?
    EDIT.....I should have added that I'm using laminate type counter top....cant afford that granite stuff $$$$$$
    9,077
    Various mechinisms designed just for this.
    From simple:
    http://www.mcfeelys.com/product/FSC-...rtop-Connector
    To more refined:
    http://www.mcfeelys.com/product/FSC-2600/Zipbolt
    If you tell them what you are going to use they will probably come pre-routed. Or they may tell you ;-)
    17,475
    tom i wouldnt order the hole precut for the sink, i would install the top then cut the hole,, once its cut you own it and everyone can make a mistake in measuring..plus with you doing the work it will make the sink side more stable and less likely to break on installation.
    Quote Originally Posted by Tom Baugues View Post
    Tom,
    I looked at the pre-made counter tops for my sister-in-law at both Lowes and Home Depot. Both places have draw bolt type connectors that fit into holes cut my the counter top maker to draw the joint tight. The slot is cut in the bottom of the counter top and is done by the manufacturer. Where are you getting yours?
    Jack
    May 2009
    Lafayette, Indiana
    2,380
    Quote Originally Posted by Jack Lemley View Post
    Tom,
    Jack
    Right now we see one from Menards that looks good to us and yes they too have the holes in the bottom of them for the draw tight connectors. I've just never done this . Maybe it will go together just fine. I'm just wondering if there were specific things I needed to look out for when joining the two halves.
  1. Oak countertop finish; advice needed.
    By Tony Maio in forum Finishing School
    Last Post: 05-13-2013, 06:41 PM
  2. The making of Jarrah Countertop
    By Tom Niemi in forum Flatwork Project Showcase
    Last Post: 07-11-2009, 01:34 PM
  3. Cutting Laminate Countertop ?
    By Ed Nelson in forum Carpentry and Construction
    Last Post: 12-23-2007, 12:36 AM
  4. Replies: 25
    Last Post: 01-31-2007, 12:17 AM
  5. Countertop Mod
    Last Post: 12-12-2006, 12:27 AM
