Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Planer woes AGAIN
    5,533
    Planer woes AGAIN
    Well, there goes my big project of the month... my Planer just croaked on me. I was just starting to plane some more boards for my cutting board project when it all of a sudden went silent on me. and a rubber seal fell out onto the feed platform. Guess that project's on hold til I figure out how to afford to get it fixed. I wasn't even in the middle of a board, it just quit.
    -Ned
    Los Angeles, CA
    2,668
    Sorry to hear that, Ned. I hope it is a simple and cheap fix.
    5,533
    Quote Originally Posted by Mohammad Madha View Post
    Thanks Mohammad, I doubt it will be. I'm debating whether to tear into it on my own or to schlep it down to the local tool repair guys... the CFO just informed me that the repair guys were out of the question... but I'm not comfortable diving into a repair situation on a motor.
    -Ned
    Dec 2008
    Portland, Oregon
    1,898
    Quote Originally Posted by Ned Bulken View Post
    When the expensive printer/photocopier in an office began print black lines on every page, the office manager called a local repair shop where a friendly man informed him that the unit probably needed only to be cleaned. Because the store charged $100 for such cleanings, he said, the manager might try reading the manual and doing the job himself.
    Pleasantly surprised by his candor, the office manager asked, "Does your
    boss know that you discourage business?"
    "Actually it's my boss's idea," the employee replied. "We usually make
    more money on repairs if we let people try to fix things themselves first."
    Jesus was a Woodworker
    13,464
    That bites Ned, sorry to hear about that. What model is it? Any smoke, grinding, or kurthunks?
    9,077
    Quote Originally Posted by Dan Mooney View Post
    There goes the coffee on the monitor again.
    Bummer Ned. It is so disappointing to be "on the move" in the shop and get stopped dead like that. What kind of planer was it?
    5,533
    Thanks Dan, that's exactly why I'm Not tearing into it.
    DW734 12.5"... quick perusal online says that $350 will get me a New one of those (useful for knowing how much to spend on repairs or not) I didn't See any smoke, but there was an odd odor when I was planing last night, so I think it may have 'been going' then. The rubber seal or belt (thinking seal as it is only about 1/8" in diameter) shows it is fairly brittle/old. The planer is about 8 or 9 years old by the calendar, and probably has only about 5 years worth of light shop usage (discounting 2 to 3 years of storage time from the total).
    There wasn't a kerthunk or anything out of the ordinary when it quit, it just went silent all of a sudden. I had my hearing protection on (direct drive motors are horribly noisy as we all know)... Have to see what my options are. I'll give the local repair shop a call and see what diagnosis will cost.
    -Ned
    13,464
    Not seeing any parts that look like a o-ring/seal...
    http://www.ereplacementparts.com/dew...2664_2986.html
    With it just quiting I wonder if it might be part of one of the caps that hold the brushes in, losing one of those would make it just quit.
    Edit: looking at pics, that would be pretty obvious...so may not be, but may check both sides of the motor to see. Possible the back one may have vibrated out and fell into the cutter.
    5,533
    well after contemplating various options, I went out and took a second look... and lo and behold, the drive belt is off. SO 'relatively' cheap fix may be possible. looks like the 'seal' may have been part of the drive belt.
    -Ned
    5,533
    I did take the shield off and check the cutterhead, as I've had a problem with a screw backing out, and bending a blade before. All is well in cutter head land... and the motor still turns, as do the feed rollers, just the blades aren't spinning. 'just' he says.
    and I did check the brushes on both sides, they're a little worn, but easily 2/3 of the brush is still there.
    -Ned
  1. planer woes
    Last Post: 04-30-2010, 07:47 PM
  2. Plane Woes
    By jim crockett in forum Neander Woodworking Q&A
    Last Post: 09-07-2008, 12:26 AM
  3. Truck woes
    Last Post: 09-02-2008, 06:09 PM
  4. Planer woes revisited
    By Billy Burt in forum General Woodworking Q&A
    Last Post: 12-05-2007, 06:52 PM
  5. DC woes
    By Jay Lock in forum General Woodworking Q&A
    Last Post: 01-17-2007, 05:25 PM
