Results 1 to 3 of 3
Thread: Raised Panel Add-on to Tall Router Fence
    I have a kitchen hutch idea that may end up with raised panels on it somewhere. I was thinking about a better, safer way to do them on the tablesaw. This magazine cover gave me an idea.
Name:	RP add on for RT tall fence v2 (1).jpg
    I already had the tall router fence (shown here) so I thought up an add-on to make it do double duty. I love my jigs but, they do take up room so anytime I can get more than one use out of a fixture, it is OK by me. I cut a piece of 1/4" MDF to the size of the tall fence face and added a couple of 1" x 3/8" end pieces for stiffness. I used a shop made fairing stick to draw a curve on a piece of straight grained oak about 1-3/4" x 1" to make the pressure bar (similar to a curved caul).
Name:	RP add on for RT tall fence v2 (2).jpg
ID:	70740Click image for larger version.
Name:	RP add on for RT tall fence v2 (3).jpg
    Prior to shaping the curve on the pressure bar, I drilled it at the drill press and then used it to line up the holes for the knobs/bolts that will hold the victim to the jig and the jig to the tall router fence assembly.
Name:	RP add on for RT tall fence v2 (4).jpg
ID:	70742Click image for larger version.
Name:	RP add on for RT tall fence v2 (5).jpg
    Here's the parts laid out and a dummy panel clamped down to show how it works. Unlike when being used for the router table, the whole jig slides along the fence to make the cut.
Name:	RP add on for RT tall fence v2 (6).jpg
ID:	70744Click image for larger version.
Name:	RP add on for RT tall fence v2 (7).jpg
ID:	70745Click image for larger version.
Name:	RP add on for RT tall fence v2 (8).jpg
ID:	70746Click image for larger version.
Name:	RP add on for RT tall fence v2 (9).jpg
    I can't actually make a cut as I need another long bolt for the pressure bar (I just faked it for the pics). I will also glue a wide strip of sandpaper along the 1/4" MDF for a better grip after I shellac the whole thing. It can dry while I run to the BORG for a few longer bolts to backfill my depleted stock.
    5,172
    "hold the victim to the jig"
    Love it!
    Here it is with all the details on. I just raised a small piece of cherry scrap. I was after something that could be touched up with a couple swipes from a hand plane and it looks like it will do that well enough.
Name:	RP add on for RT tall fence v2 (10).jpg
ID:	70751 . Click image for larger version.
Name:	RP add on for RT tall fence v2 (11).jpg
    There's variations with a defined raised area or one more subtle as shown. At any rate it should be interesting and only takes up a few more inches of the nook where I stash the tall router table fence anyway
  1. Router Table Fence - Tall, Ver-2
    Last Post: 05-03-2013, 11:07 PM
  2. Replies: 8
    Last Post: 08-05-2011, 11:48 PM
  3. Raised Panel resized?
    Last Post: 01-16-2011, 04:27 PM
  4. vertical raised panel bit vs router horsepower
    Last Post: 12-30-2009, 12:25 PM
  5. Replies: 7
    Last Post: 09-12-2009, 02:42 PM
