Results 1 to 4 of 4
Thread: Backwards router?
    Oct 2009
    Dennison, MN
    512
    Backwards router?
    Anyone know if a Porter Cable 1609 can be wired/jury rigged to run counter clockwise?
    or, does anyone know of a router that runs in reverse?
    Looking to do a left and right router for doing dovetails. It would alleviate the need to cut the bottoms off, or having to deal with a small amount of tear out on two corners of the drawer bottom.
    Yes, I know I'd need a separate bit as well.
    "Do, or do not. There is no try."
    -Yoda
    Central NY State
    3,374
    Interesting idea. You'd need a custom backwards bit, right?
    13,450
    Not all motors are going to be the same, but I would think you could try switching the brush leads around on the motor. Concern I guess would be if the collet needed to be a reversed thread or if it would work loose if it wasn't.
    Oct 2009
    Dennison, MN
    512
    bits are available.
    The collet shouldn't be a big deal. I run shapers backwards all the time with climb cuts, you just gotta get it really tight.
    -Yoda
  1. one step foward, 2 steps backwards
    By allen levine in forum Old Iron
    Last Post: 02-03-2014, 03:12 PM
  2. Coring a bowl backwards
    By Rich Soby in forum General Woodturning Q&A
    Last Post: 09-28-2011, 04:54 AM
  3. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  4. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  5. Ho hum, don't forget to do it backwards, Virginia...
    By tim Rowledge in forum General Woodworking Q&A
    Last Post: 09-18-2007, 05:36 AM
